Boot scratching the swingarm? My 'how to' fix here... - Kawasaki ZX-10R.net
post #1 of 2 Old 10-20-2007, 12:37 PM Thread Starter
Doughboy's Avatar
My Sidi boots had been scratching the right side of my swingarm, to the point where it was down to the bare aluminum. I finally decided to fix it this week. Here's what I did...
The damage is from the hard plastic around the ankle on my boot. I guess my foot position needs some work!
OK. Ordered these OEM "frame protector decals" from my local dealer/stealer. $10 a pop. These are the same parts that are on the upper frame, where your knees would rub the frame.
These are the tools I thought I might use. Only used the scissors and a normal ball point pen (and a screwdriver handle later on).
Took the decal out to the bike, found a shape that would cover the area where my boot might contact. Traced a basic pattern while holding it against the swingarm. The pen will wipe off with a little wax, so I wasn't worried about making mistakes.
Cut the basic shape out, then refined it to the finished piece with rounded corners. The scissors worked well. The decals are flexible, but semi-stiff, so it was pretty easy to cut.
Thoroughly cleaned the swingarm on the bike. I scrubbed for like 10 minutes, making sure all the road grime was off. If I had some alcohol, I would've wiped it down before applying the decal.
Applied the decal. Start in the middle and work it out to the edges. This minimizes any air bubbles. Also used a screwdriver handle to help adhere the decal. Piece of cake!
Can't even see it from 10ft away. Looks like a stock piece! This was a no-brainer, easy fix.
Anyways, just wanted to share...
Doughboy is offline
post #2 of 2 Old 10-20-2007, 12:52 PM
Big Daddy's Avatar
Images: 38
Discuss this here. https://zx-10r.net/forum/showthread.php?t=46839
Big Daddy is offline
Boot scratching the swingarm? My 'how to' fix here... Doughboy Performance and Tech 32 11-06-2014 10:47 PM
boot prices SOUN1 Vendors deals 4 01-29-2007 11:29 AM
What's this all a-boot, no customers?!?! Kickaho The Out House 19 05-09-2006 05:08 AM
Boot Humour JBJ The Out House 19 02-24-2006 09:31 PM
MX boot price's NWZX10 Vendors deals 0 04-11-2005 12:00 AM
You may not post replies
