**WARNING** Possible BRAKE issue for many - Kawasaki ZX-10R.net
post #1 of 9 Old 09-22-2006, 10:34 PM Thread Starter
Tonight as I was checking the brakes on my girlfriends 636 I noticed here CRG lever was contacting the double Banjo fittings and stopping the lever from coming the rest of the way in. When I started really looking in on this what I found was the little leg that activated the brake light switch was contacting the Banjo HARD! This is with aftermarket Galfer lines, but any aftermarket with DOUBLE banjo will cause this and it's worse with the CRG's or Pazzo's. I removed it and ground off the little leg untill it cleared and Presto her brakes are 100% better. I didn't notive this because I bled them with the stock lever and the little leg isn't nearly as large.
NOW on to my own 10R. Same set up except I have an 05 636 master with stock lever. I noticed that the little leg also contacted the double banjo when the lever was really close to the bar. THE BIG issue here is on the 10R it could have caused the lever to stick and cause a crash!!!!!!!!!!!
Everyone with these lines needs to check for this and with the 10R that has the 636 master GO LOOK!!! it could save your life.. I had to grind the 10R as well... NOW I'm going to kick my own ASS for not noticing this sooner.. DAMN! ROOKIE mistake that could have ened really bad!! Guys go check
Gunner is offline
post #2 of 9 Old 09-23-2006, 10:00 AM Thread Starter
I don't have any pictures. But all you have to do is pull the brake lever in and see if it contacts the Banjo ends with the little leg that sticks down to activate the brake light switch. If you have switched to the 636 master on the 10R it most likely will hit once the lever is pulled hard to the bars mine did. AND on the 636 if you have CRGs or Pazzo's with aftermarket lines it will most likely hit as well.
That's a very tight spot ti try and get a picture and it wouldn't show up for shit. It would be next to impossible to get the correct camera angle.
Gunner is offline
post #3 of 9 Old 09-23-2006, 11:22 AM
Big Daddy's Avatar
Images: 38
I have no such problem. However my setup may be different. I do have a 6r radial MC with 6r Galpher lines with 1 line having a 90degree bend and the other has a 45degree bend which gives plenty of clearance when or i should say if the lever traveled in that far.
Big Daddy is offline
post #4 of 9 Old 09-23-2006, 11:32 AM Thread Starter
I have the exact same set up BD. I have Galfer lines for a 636 as well. I never noticed it on my 10 till I found hers on the 636. The 636 was bad due to the CRGs. My 10 was slight but it could have caused the lever to get jammed and locked in. Since I have 2 bikes sitting here and both have this issue I can only assume others may have it as well. The brakes worked on both bikes, but it was flexing the little LEG HARD on the 636. I had the CRG levers on the 636 with ZERO problems before the Galfers. That's why I didn't spend any time checking for problems.(again a rookie mistake.....always check everything) And since the brakes were already bled I never had the lever pulled that far in. The lever felt HARD and firm as hell. I thought this was a great feeling lever, but it was mechanically jammed against the banjos. Now that it's cleared it feels normal for a Kawasaki lever pull again.
Gunner is offline
post #5 of 9 Old 09-23-2006, 11:37 AM
Big Daddy's Avatar
Images: 38
could the diff be my Pazzo lever??
post #6 of 9 Old 09-23-2006, 12:29 PM Thread Starter
It could be BD, but mine hit with the stock lever. AND I even have the stop removed and the Banjo rotated away ever farther away than normal. It's the TOP banjo that the lever hits. Again this is with the 05 636 master and NOT the stock 10R master. Both these bike have Galfer SuperBike line kits for an 05 636.. BD don't you have a different brand of lines??
Gunner is offline
post #7 of 9 Old 09-23-2006, 12:47 PM
Big Daddy's Avatar
Images: 38
heck i done forget what brand they are well its either Galpher or Goodridge but either way i have no clearance probs.
ID:	37813   Click image for larger version
post #8 of 9 Old 09-23-2006, 01:28 PM Thread Starter
BD............My top banjo isn't bent 90 degree like that on either set. I'm sure mine are both Galfer.
Gunner is offline
post #9 of 9 Old 06-26-2007, 02:15 PM
Big Daddy's Avatar
Images: 38
Discuss this topic here. https://zx-10r.net/forum/showthread.php?t=27407
**WARNING** Possible BRAKE issue for many Gunner Performance and Tech 14 07-27-2009 04:51 PM
Front Brake issue hotfocuson18s The ZX-10R 12 05-29-2007 05:52 PM
Issue with my 06' 10 GARSZX10R The ZX-10R 28 03-21-2006 10:49 AM
Brake issue? K10 Performance and Tech 8 08-12-2005 10:49 PM
You may not post replies
