Gen 4: 2011-2015 WTB: Kent KAW35 camshafts - Kawasaki ZX-10R.net
 4Likes
  • 1 Post By michael4012
  • 1 Post By Neonmarine
  • 2 Post By michael4012
post #1 of 9 Old 06-05-2019, 04:22 PM Thread Starter
Carlos76's Avatar
Looking for Gen4 Kent KAW35 camshafts.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #2 of 9 Old 06-05-2019, 04:49 PM
michael4012's Avatar
Have thought about asking Kent Cams
Neonmarine likes this.
michael4012 is offline
post #3 of 9 Old 06-05-2019, 04:59 PM Thread Starter
Carlos76's Avatar
No. I guess they could be found cheaper second hand.
Carlos76 is offline
post #4 of 9 Old 06-05-2019, 05:41 PM
I have a set of brand new still in the box not even had the plugs fitted, there super polished. Do want pictures
post #5 of 9 Old 06-05-2019, 08:15 PM
Formerly CLCRACINGAaron
Neonmarine's Avatar
For a Gen5?
michael4012 likes this.
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is online now
post #6 of 9 Old 06-06-2019, 01:14 AM
Originally Posted by Neonmarine View Post
For a Gen5?
they are the same G4 & 5 profile is identical! Its an incredible cam, no need for heavy springs stock springs are good to go because the profile is actually softer than stock until approaching max lift where the lift is significantly higher the stock spring is stronger.
post #7 of 9 Old 06-06-2019, 01:37 AM
Actually I did test fit the plugs on the ex cam.
ID:	422635   Click image for larger version
ID:	422637   Click image for larger version
ID:	422639   Click image for larger version
ID:	422641   Click image for larger version
post #8 of 9 Old 06-06-2019, 01:10 PM
The tech on these cams is below, kent quote 110 110 which is good but all the BSB teams who use these go 112 112 which is slightly better for race, the pick up comes much lower allowing the Superbikes higher torque earlier. Even Tony at Kent Cams is open about the teams using 112 112 and agreas track days and road 110 110 race 112 112
Part No. KAW35
Manufacturer Kawasaki
Engine 1000 R 2011-12
Description Race
Power Band N/A
Specifications
Cam Lift (mm) 11.20mm Inlet/ 9.40mm Exhaust
Duration at 1mm 262 Deg Inlet/ 258 Deg Exhaust
Full Lift Inlet 110 Deg ATDC/Exh 110 Deg BTDC
LTDC 2.95mm Inlet / 2.40mm Exhaust
Timing 21/61 59/19
Valve Lift (mm) 11.00mm Inlet/ 9.20mm Exhaust
VC (mm) 0.20 mm Inlet / 0.20mm Exhaust
Required Parts
No required parts found at this time
Carlos76 and Neonmarine like this.
post #9 of 9 Old 06-10-2019, 05:39 AM Thread Starter
Carlos76's Avatar
Found intake and two exhausts cams.
Missing one intake KAW35.
Carlos76 is offline
