Weight loss for the ZX12 - Kawasaki ZX-10R.net
post #1 of 11 Old 11-22-2005, 07:13 PM Thread Starter
A mate of mine has a 12 and he's thinking it needs to loose some weight.
Are there any easy weight loss ideas kicking around ?
We can do the usual , tool kit out, alloy/Ti bolts, 520 conversion etc.
I'm wondering more about specific ZX12 things ?
Thanks in advance
stocky is offline
post #2 of 11 Old 11-25-2005, 06:56 AM
Ruthless Racing's Avatar
Images: 9
Thanks in advance
I doubt you would want to do the 520 conv. on the 12R. You could take the rear sets off, take one of the brake calipers and rotors off one-side of the front wheel, eat at Subway.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #3 of 11 Old 11-25-2005, 02:21 PM
magzx12r's Avatar
A full Ti exhaust will drop a lot of weight. Also could get some aftermarket wheels to drop a good bit of weight.
Mark
magzx12r is offline
post #4 of 11 Old 11-25-2005, 02:55 PM
Why would anybody wanna do that???
for weight removal without spending big $$,
- replace stock rear plastics by an undertray (loose 2/3 Kg)
- remove passenger foot-pegs (loose 0,5-0,8 Kg)
- replace the bar weights by some delrin/abs plastic units (loose 0,5 Kg)
- use carbon rear and front fenders (loose 1 Kg)
- smaller/lighter mirrors (loose 1 Kg)
pedrodani is offline
post #5 of 11 Old 11-26-2005, 09:14 AM
BANNED
Phantom12's Avatar
-Remove KLEEN air system
-180mm rear tire
-Remove rear pegs
-Remove mirrors
-Remove turn signals
-Remove mudflap (rear fender)
-Use less oil (1/8 inch showing in sight glass)
-Fiberglass bodywork w/o headlights (use small one)
-Aluminum rear sprocket (AFAM suggested)
-Lighter 530 chain
-Magnesium Wheels
-Titanium Rearsets
-DIET!!!! (cheapest and easiest weight loss)
-Run with 1/4 tank of gas
Don't remove/replace the barends, they act as stabilizers.. unless you have a steering damper, don't touch them.
Phantom12 is offline
post #6 of 11 Old 11-26-2005, 09:40 PM
Images: 9
Um, to lose weight!!! Duh
Kenny Poppell
Special Thanks:
Performance Psycle
Richies Tires
post #7 of 11 Old 11-27-2005, 08:10 AM
Duh ?? since when loosing 50% of the braking capability is considered a smart thing?
post #8 of 11 Old 11-27-2005, 09:20 AM
Images: 9
I see your in Portugal and obviously not familiar with grudge racing. But around here most of your grudge bikes are trying to lose as much weight as possible. I've seen some bikes with no rear brake at all, no caliper or rotor and the front only had one caliper and rotor . But I can show you pic after pic of bikes with only one front caliper and rotor and for what you say , um to lose weight!!! http://www.mirockracing.com/gallery/...1/dsc_0057.htm
Kenny Poppell
Special Thanks:
Performance Psycle
Richies Tires
post #9 of 11 Old 11-27-2005, 10:17 AM
OK, I can see it now. Thanks for clearing that out for me.
post #10 of 11 Old 02-15-2006, 09:54 AM
BackMarker's Avatar
These guys are straight liners. Drags, 9/10's ect. They have plenty of room to slow down.
WERA Expert #760
'10 N.E./Mid-A Hwt. Senior Superbike Champ
'09 N.E. "A" Superstock Champ
'09 Senior Superbike Champ
www.sichertengraving.com - www.Karns-performance.com - www.Absolutesignshop.com - www.Untamedvelocity.com - www.keystonegenerators.com
Vortex - Hotbodies - Scorpion Helmets - LP Racing - Vesrah - Pitbull
BackMarker is offline
