I'm sorry if it's not the right place to post this but i'm kind of a newbee.
-Gilles vario bars (I have ohlins forks)
-Gilles chain adjuster
-Brembo front cast master cylinder with all the necessary hardware (Light switch, banjo...) don't know the piston size but 19x20 should be ok.
-Clutch + brake levers that can match
-16 Steel front sprocket 525
-Chain 525
-45 Rear sprocket (not aluminium) 525
-Brake rotors front + rear
Thank you
-Chain 525
Thank you
