* Each lever is made out of billet aluminum and is an ideal replacement of your current factory style or after market lever. It has an easy click to adjust miniature clicker that allows riders to manipulate the lever position even while riding. Each lever is designed for OEM style master cylinders. Although priced lower than the competitor, the quality is exactly the same with sealed roller bearings installed for smooth adjustments as well as the elimination of wear between contact points for longer lasting use.
These are a good quality lever at a great price.
$145 shipped per set anywhere in the lower 48!!
currently we have access to the following kawasaki models in short levers only:
