New Ignition Unit for ZX-10 - Kawasaki ZX-10R.net
post #1 of 2 Old 02-09-2006, 02:43 PM Thread Starter
Ryan Schnitz's Avatar
New Ignition Retard/Advance Unit for ZX-10
Picture of EFIR-12 for Reference only.
The EFIR-ZX10-04 Retard Module allows the user to progressively retard the ignition timing on the 2004/2005 ZX-10 with a 12 volt signal. This is a Must for Bikes with Nitrous or Turbos
The EFIR-ZX10-04 also has a timing advance feature that can be used when running the bike without nitrous. This timing advance is applied progressive between 5,000 and 6,000 RPM. Stock timing is used below this rpm to prevent detonation. By advancing the engine at higher rpm, a horsepower increase of as much as 2% can be seen.
This unit plugs right into the factory wiring harness, and is 12 volt activated. Hook it right up to your nitrous solenoids or a pressure switch on your turbo bike, and retard the timing to save your engine.
It is programmable with dipswitches from 0-16 degrees of timing retard, and also has dipswitches to adjust the built time from .250 to 4 seconds.
EFIR's are easy to wire, but you have to wire them correctly. If not wired correctly the bike won't start, or will shut off when it's activated, so read first then wire!
Available March 2006 Preorder yours today to avoid backorder delays!
http://secure.mycart.net/catalogs/ca...showprevnext=1
$334.95
Ryan Schnitz is offline
post #2 of 2 Old 03-07-2006, 02:07 PM Thread Starter
Ignition Module - Tested finally !! Ivan Performance and Tech 70 01-25-2006 11:56 AM
TRE unit acting weird!!!! madbadger Performance and Tech 0 08-07-2005 04:19 PM
TRE unit acting weird!!!! madbadger Performance and Tech 10 08-01-2005 01:29 AM
Ignition Advancers KawiMuscl Performance and Tech 1 05-04-2005 11:05 AM
Ignition Advancer BNninja Performance and Tech 10 04-30-2005 06:38 AM
