New HM RL Lite Quickshifter Now Available... - Kawasaki ZX-10R.net
post #1 of 5 Old 08-26-2011, 11:18 AM Thread Starter
lexusrx's Avatar
The new RL quickshifter is a no frills stand alone QS system made by HM. If you dont want all the additional fluff, this is where you want to go.
I have tested these units pre-production, and they work VERY well. Simple hookup, and very simple setup. You have high/medium/low cutout settings (normal recommended settings will be medium cutout). Once you do that, you ride!
one of the best things is price. $279 SHIPPED in the lower 48!!
you can order them here:
http://www.superbikesupply.com/mm5/m...hifter-rl-lite
Features of the HM RL Quickshifter:
1) HM RL Quickshifters are Strain Gauge activated; the same technology used in MotoGP. Nothing is better; period!
2) No moving parts means the RL Quickshifters are virtually indestructible and carry a Lifetime Warranty against product malfunction or defect. (Crashing and breaking the product does not count.)
3) HM RL Quickshifters are the kindest and gentlest way to treat your gearbox. The RL uses the ignition side of the motorcycle to kill, which is far kinder then most other designs that come from the fuel side.
4) HM RL Quickshifters are STAND ALONE systems, integrated to the ignition side of the motorcycle as a quickshifter should be. No need for complex interfaces with other fuel side ECU's, no software glitches, no need for constant adjustments and no chance of failed interference to any other operational aspect of the motorcycle.
5) HM RL Quickshifters kill from the ignition side of the engine, so there is no chance of "extended" fuel burning, secondary injectors (which most modern sportbikes have) that are not shut off, or any other problems that might be associated with fuel side controls. Spark is dead, gearbox unloads and the RL initiates an ultra smooth, gentle and unquestionably fastest gear change you can get.
6) Every HM RL Quickshifter works in EITHER the "up" or "down" shift pattern. No need to buy "one or the other" for your shift pattern, and you never have the wrong setup.
7) Every HM RL is 3-way adjustable for lever sensitivity, so you can adjust for the specifics of your machine, gearbox and riding style. Nothing is kinder to your gearbox...
8) The HM RL is transportable, meaning it can be used on many different machines with the correct wiring loom and shift rod length. The RL is not tied to any ECU "box", so you can reuse your investment over and over! Multiple bikes, changing bikes during the season or buying a new one means you can most likely bring your Annitori RL Quickshifter with you for very little added expense.
9) HM RL wiring looms are "plug in and go". No need to splice or cut in any way, no complications with other ECU's. Straight bolt on application, and clean removal if the time or need ever comes.
Retail is for squids. Shop like a pro at Superbike Supply.
[email protected]
https://www.facebook.com/superbikesupply
www.forum.superbikesupply.com
1-828-287-2101
lexusrx is offline
post #2 of 5 Old 09-15-2011, 01:56 AM
Baddie's Avatar
Just wondering if anyone has installed one of these?
Im currently running pcv with auto tuner and many ppl are saying you need to be connected to injector for it to work???
Baddie is offline
post #3 of 5 Old 09-15-2011, 08:25 AM Thread Starter
lexusrx's Avatar
You don't hook to the injectors, the quickshifter hooks to the ignition coils.
[email protected]
1-828-287-2101
lexusrx is offline
post #4 of 5 Old 09-15-2011, 09:16 AM
Baddie's Avatar
And you are able to have push or pull set up?.
Baddie is offline
post #5 of 5 Old 09-20-2011, 09:24 AM Thread Starter
lexusrx's Avatar
Yes, it works for both set ups.
[email protected]
1-828-287-2101
lexusrx is offline
Nolan X-Lite helmets akkordn2u General Motorcycle Discussions 5 03-02-2012 03:00 PM
marker lite? red636girl General Motorcycle Discussions 6 08-11-2011 09:25 AM
Another blinking fi lite. nczx-10r Performance and Tech 2 05-29-2009 12:25 PM
fi lite blink jani Performance and Tech 8 01-23-2008 10:59 AM
FS: EBC Pro-Lite UK Race Brake Rotors beansbaxter Parts, Gear and Accessories 0 01-16-2006 01:56 PM
