Adjustable suspension Linkage for ZX-10 - Kawasaki ZX-10R.net
post #1 of 1 Old 05-03-2005, 02:56 PM Thread Starter
Ryan Schnitz's Avatar
http://secure.cartsvr.net/catalogs/c...showprevnext=1
Fine tune weight transfer to rear wheel to accommodate rider weight, swingarm length, riding style, etc.
Will work with stock shock, no need to buy an expensive shock to get the weight transfer you need! Will also work great with an aftermarket shock though.
No more having to send out your shock to get it revalved or re-sprung when you make changes such as swingarm length, or when you want someone heavier or lighter to ride your bike that's set-up for your weight. Just adjust the LinkPro to suit the new weight or set-up environment and you're ready to race!
Will significantly cut 60ft. times, especially for average riders.
Keeps the bike lower, longer through the pass for better E.T.'s.
For best results, use in conjunction with the fully adjustable lowering links to properly set ride height. Comes with bearings already installed. Customer uses stock spacers, washers, and bolts.
Name:	05 AMR1002 0507psd.jpg
Ryan Schnitz is offline
Settin Suspension Sag hillcountry10r Performance and Tech 20 02-07-2007 04:31 AM
Adjusted My Suspension litrejunkie The Out House 10 04-07-2005 02:22 PM
Settin Suspension Sag hillcountry10r How To... 2 02-05-2005 02:29 PM
suspension settings? cain772 Performance and Tech 8 01-06-2005 08:07 AM
Track stock suspension setup? Rattler Performance and Tech 6 01-04-2005 04:14 PM
