06 ZX10R rear sprocket advice - quotes - Kawasaki ZX-10R.net
post #1 of 16 Old 04-17-2006, 07:45 AM Thread Starter
Gents, an easy one - can I get some pm mail from those who have on hand a rear sprocket for my new 06 ZX10R? Not swapping chains, so we are talking about a 525 chain, I want to go two teeth above stock (so that would be 42 teeth, but correct me if I am wrong) and I would prefer not steel but alum, and would like ano black - I think Renthal has one like that?
Could also use some black spools for the rear on this bike too, while you're at it.
TIA
Jack
06 Kawasaki ZX10R, Akra Carbon-Hex slip ons, Sato rearsets, -1 F, PCIIIusb, TRE, BMC Race AF, Speedohealer, blah blah blah
[other things in my garage with engines and tires: 02 Avalanche, 65 L76 Corvette, 7.0 hp Sears lawnmower, 10 hp MTD Snowblower . . . ]
ctjackster is offline
post #2 of 16 Old 04-17-2006, 10:23 AM
lexusrx's Avatar
pm sent
Retail is for squids. Shop like a pro at Superbike Supply.
[email protected]
https://www.facebook.com/superbikesupply
www.forum.superbikesupply.com
1-828-287-2101
lexusrx is offline
post #3 of 16 Old 04-20-2006, 06:05 PM
I am also thinking aout going with a 42 rear sprocket, but I am looking for gold anodized. Will the stock chain work with a 2 up rear sprocket?
tbcustomz is offline
post #4 of 16 Old 04-20-2006, 06:51 PM
So will the 42 fit an 06 with stock chain? If so I will take it if there are no scratches, etc.
post #5 of 16 Old 04-20-2006, 07:50 PM Thread Starter
question of the day is whether there is enough adjustment room in the rear axle to accomadate two more teeth in the reer sprocket - my 06 ZX10 has nearly two hash marks of inward adjustment available now (new) before the chain has strecthed - two more teeth is basically equivilant one tooth more chain engaged, or 1 link overall, and 1/2 link when you do the two sides of the chain math - - each link on the 525 chain is 5/8s, I think, so a little over a 1/4 of adjustment would be required, roughly, to accomadate the move from 40 to 42.
Tha't all speculation, real world advice from 05 owners is that they were unable to go immediately to a 42 tooth sprocket using the stock chain, I have been told.
I prefer a larger rear sprocket as oopposed to a smaller front sprocket on princple, but that option is always available and do-able.
I may just get the 42 tooth sprocket in hand and try it out and see if I can get the rear axle back on - I'll report back
Jack
post #6 of 16 Old 04-20-2006, 09:24 PM
Andy's Avatar
Images: 25
You're right ct, on the 04-05 a 112 link is needed to use the 42t sprocket. The 110 was too short.
Andy is offline
post #7 of 16 Old 04-20-2006, 09:30 PM
circusnuts's Avatar
Yeap, I couldn't accomodate the move from a 39T to a 40T (one tooth) with the O.E. chain on my 04.
Dress for the slide & not the ride
circusnuts is offline
post #8 of 16 Old 04-21-2006, 04:42 AM
Big Daddy's Avatar
Images: 38
wish ya luck Ct
Big Daddy is offline
post #9 of 16 Old 04-21-2006, 07:17 AM Thread Starter
Thanks, and thanks for the heads up (BD) in the first place, the benefit of a Kawi forum with guys watching out for you for sure. Sure sounds like it is a no go though, at least not with a brand new chain (When you hear that folks couldn't even go up one tooth, that's troubling!)
Jack
post #10 of 16 Old 04-25-2006, 03:41 PM
oz914's Avatar
What would be the benifit of going up 2 in the rear as opposed to down 1 in the front and up 1 in the rear? I'm thinking about doing sprockets soon and would like all the info I can get. Thanks in advance.
oz914 is offline
04/05 ZX10R Rear suspension mod wstaab Performance and Tech 106 01-19-2015 08:52 AM
Installing Rear shock 101: ZX10R gets Ohlin's upgrade Vonstallin Performance and Tech 38 08-08-2011 08:31 AM
Installing Rear shock 101: ZX10R gets Ohlin's upgrade Vonstallin How To... 1 10-11-2005 10:15 AM
Vortex Rear Sprocket 41t. for 04' ZX10R BIKEMIKE Parts, Gear and Accessories 1 03-27-2005 08:47 AM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
