ZX6 - late model motor swap - Kawasaki ZX-10R.net
post #1 of 2 Old 07-31-2008, 06:10 PM Thread Starter
JeredH's Avatar
Send a message via MSN to JeredH
I have a buddy with a 2003 ZX636R and he needs to replace crank, rod and piston.
I am parting out a 2005 ZX600RR motor, and here is what we want to do.
Combine the upper and lower case of the 600RR with the head of the ZX636.
Note the difference in years here.
What do y'all think...is it possible?
2005 ZX-6RR
2004 ZX-10R
2003 KX 250
WERA Novice #616
JeredH is offline
post #2 of 2 Old 07-31-2008, 10:35 PM
Azzkker's Avatar
the rr head has much better porting from the factory, as well as a higher lift cam shaft on the intake side. if he is running the 599 rr motor i would not install the 6r head on it, if its even possible. what he could do is install the exhaust cam off an 05-06 636 on the 599rr motor for a boost in performance and have them degreed in, or use the trans off the rr motor and replace his bad rotating assembly and install an 05-06 636 head and cams on it.
Azzkker is offline
Late Late Christmas Present!!!!! Enzo10 The Out House 42 03-02-2008 06:20 PM
should I swap to a 06-07 race tail along with my front end swap? garth285 The ZX-10R 10 12-05-2007 09:21 PM
What r u doing up so late? madkaw77 The Out House 14 08-11-2006 10:07 PM
Late secondary's ?? FAF Performance and Tech 2 05-25-2006 09:59 PM
late for work modiggs Pictures and Videos 11 12-16-2004 10:01 AM
