zx6 caliper lines - Kawasaki ZX-10R.net
post #1 of 4 Old 01-01-2015, 03:59 PM Thread Starter
ZX10Rip's Avatar
zx6 caliper lines
For those that put zx6 brake calipers on their Gen 1 zx10r what brake lines did you use. Because the bango bolt fitting is located at the top of the caliper it looks like the Gen 1 lines might be to long. Right now I have Goodridge stainless lines with the stock calipers. Let me know if you guys used lines from another bike.
ZX10Rip is offline
post #2 of 4 Old 01-02-2015, 12:43 AM
TechX's Avatar
Those lines will work fine. The location of the 6r banjo bolts are just a bit higher than the stock tokico calipers. Just rotate the line out a bit and your good.
TechX is offline
post #3 of 4 Old 01-02-2015, 04:00 AM
or10r's Avatar
I just re routed my lines a tad. They are a bit longer but look/work fine.
or10r is offline
post #4 of 4 Old 01-02-2015, 06:18 AM Thread Starter
ZX10Rip's Avatar
Thanks, I was debating on getting a set of Galfer lines for a 2008 ZX6r because I already have the master cylinder from a ZX6r on my Gen 1 ZX10r and the banjo bolts attach to the bottom of the master cylinder not the end as on the stock Gen 1 master cylinder, which makes my lines a little longer right now. I will see how they work with the new calipers after I get them and go from there.
ZX10Rip is offline
Wanted: ZX14/ZX6 Nissin Caliper (right side) nolaZX10 Wanted: Buy or Trade 0 11-17-2011 05:15 PM
Opinions on pads with ZX6/ZX14 caliper change (street/track use) Grease The ZX-10R 33 09-01-2008 07:53 AM
ZX6/14 Calipers and Galfer Lines Questions!!! Blink180Wilhelm Performance and Tech 2 04-21-2008 04:54 PM
3 lines into caliper Vio General Motorcycle Discussions 3 01-18-2008 11:52 PM
FS:06-07 right clipon/caliper/lines 925stunna Parts, Gear and Accessories 1 10-02-2007 03:50 PM
