Zx14 shifter on zx10r - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SkyDork
post #1 of 7 Old 08-29-2018, 07:30 PM Thread Starter
I decided to try out a 06 zx14 shifter on a 2004 zx10r to try and get ride on slop in the shifter and have a easier replacment if you damaged the shifter. You will need a 10mm wrench and a 8mm wrench.
Take off the OEM rod and the swivel that connect to the shifter shaft.
Leave the heel rest peg in place.
Install the zx14 shifter pedal to the zx10r shaft. (Keep adjusting it by positioning it on the shaft
till it's to your liking.
Tighten the 8mm bolt and enjoy a better pedal feel, quicker shifting, better acceleration, stability, easier shifts.
ID:	419563   Click image for larger version
bigirb2002 is offline
post #2 of 7 Old 09-07-2018, 11:22 AM
Melampus's Avatar
Question >> impetus <<
BIGIRB2002 <> I'm interested what made you do this. Had you seen this done elsewhere? How has it worked out for you? Do you feel any lateral flex in the shifter lever when shifting?
Melampus is offline
post #3 of 7 Old 09-07-2018, 12:15 PM
SkyDork's Avatar
I know of another person who's done this. The shift lever becomes more secure since it's directly connected to the shift rod. The stock shift lever uses a torque tube and a plain bearing arrangement. The plain bearing is what causes the slop referenced.
The problem with this set up is that it reverses the shift direction into the GP pattern (1 up, 5 down). That's the good part. The other issue is more related to track use. The shift pedal is locked in that position. For adjustable rearsets, moving them up and back, the pedal spacing increases since the pedal doesn't move with the peg. And when you crash on the left, the shift pedal gets damaged and is harder to replace. You can't just swap the rearsets out and move to the next session. That's the reason it doesn't come from the factory this way.
If you don't adjust your rearsets and like the reverse pattern, then you can do it this way. Not me though.
Melampus likes this.
#WordCrimes
SkyDork is offline
post #4 of 7 Old 09-07-2018, 03:20 PM
I like it, going to order the part. I think this will work better with my Nitrous powered air shifter ram I am building.
Boxtradamus is offline
post #5 of 7 Old 09-07-2018, 06:29 PM
Melampus's Avatar
Cool >> Johnny on the Spot <<
SKYD <> Once more, my hat tips to you, fine sir. Thank you.
Melampus is offline
post #6 of 7 Old 09-25-2018, 04:30 AM
I did the same thing to my drag bike 2 years ago, for the same reason of eliminating slop. I ended up getting a shifter from junk yard for an older kawasaki bike (was an 1100 I think). Same concept as using the 14 shift lever, but I think the one I have is a bit longer which would be good for people still foot shifting.
'08 10R, Lime/Black
Flashed ECU, PC5,WBC, custom shift light, shifter w/co2, side winder, BMC race, lowered, stretched,-2/+4, velocity stacks, little spray, nos mini.....
MORE TO COME
medicbaldwin is offline
post #7 of 7 Old 09-25-2018, 10:47 AM
The ZX14 one was the perfect length for mine. Got my air shifter working using the 14 lever.
https://www.zx-10r.net/forum/f32/nit...er-351251.html
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
air shifter, shinko tire and zx14 rear shock salvatrucho16 Parts, Gear and Accessories 3 09-18-2014 07:17 PM
Gen 3: Air shifter/Shifter Fork issue? Please help! madkaw08 Performance and Tech 6 03-25-2014 11:07 PM
the difference between an Air shifter and Quick shifter Dam Fool 3000 The ZX-10R 34 10-14-2010 11:22 AM
zx14 build for the maxton! first zx14 to be 200mph? 10 speed ZX-14 Discussion 17 08-29-2007 09:57 PM
Electric Shifter or Air Shifter??? Stud_wit_style The Out House 8 10-19-2005 06:41 AM
