ZX14 calipers to replace my zx10 ones - Kawasaki ZX-10R.net
post #1 of 16 Old 05-21-2013, 05:41 PM Thread Starter
Hey guys,
I have an 07 zx10 and im not happy with the braking perfomance and was reading that swapping in the nisin zx14 calipers were a realtievely cheap fix to the issue. if i do this swap i will also be doing ss lines...any thoughts or guidance?
thanks
bostonstrong is offline
post #2 of 16 Old 05-21-2013, 06:50 PM
SkyDork's Avatar
Yup, searching will provide the answers you need. It's a popular mod and there's plenty of info for you on this. It's well worth the effort to do the swap.
#WordCrimes
SkyDork is offline
post #3 of 16 Old 05-21-2013, 07:32 PM
beaver76's Avatar
To bad there is not a how-to on this
beaver76 is offline
post #4 of 16 Old 05-21-2013, 07:54 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
hellsrazor is offline
post #5 of 16 Old 05-21-2013, 08:13 PM
SkyDork's Avatar
A how-to to unbolt the calipers and bolt on the new ones? Well there ya go, that's pretty much the how-to.
#WordCrimes
SkyDork is offline
post #6 of 16 Old 05-21-2013, 11:12 PM
Nutter34's Avatar
You don't really need ss lines... The standard lines are sufficient.
Thoughts... Have a good look at the crush washers between the bolts and banjo fittings. Some people re-use them, but they are cheap at Kawi...
I've had the 14 calipers on my 06 and Blade calipers on my 07. Both with standard lines... No issues.
"You are only young once, but you can stay immature indefinitely."
Nutter34 is offline
post #7 of 16 Old 05-21-2013, 11:58 PM Thread Starter
awesome thanks guys for the info
post #8 of 16 Old 05-22-2013, 03:33 PM
CMEJATT's Avatar
Can u use the same brake pads for zx14 from Orem zx10r. Caliper.. ?.. Also do u need to bleed the brakes right
CMEJATT is offline
post #9 of 16 Old 05-22-2013, 03:54 PM
SkyDork's Avatar
No, the ZX-14/ZX-6/Concours Nissans use different pads than the ZX-10. And if you're swapping calipers, of course you'll have to rebleed the system cause you have to disconnect the lines.
#WordCrimes
SkyDork is offline
post #10 of 16 Old 05-22-2013, 04:22 PM
CMEJATT's Avatar
Ok cool thanks I guess I'll just wait to order my ss lines then ..
CMEJATT is offline
Gen 2: zx14 calipers toothless Wanted: Buy or Trade 7 03-19-2013 12:34 PM
Galfer front brake parts needed '07 zx10 w/zx14 calipers Grease Vendors deals 1 10-24-2011 01:33 PM
Brake pads question, zx14 calipers, will zx10 pads fit xx8055NIACxx Performance and Tech 6 04-05-2010 06:26 PM
I need zx14 calipers sladkixxx The ZX-10R 22 04-24-2009 09:59 AM
zx14 calipers and zx10 ss lines? sch2046 Performance and Tech 2 01-17-2008 10:23 PM
