zx10r tre tech question - Kawasaki ZX-10R.net
post #1 of 3 Old 07-19-2010, 04:32 PM Thread Starter
Hi All, i am a newbie and i know this tre type question has been asked 100000 times but i cant find the info i need.
Q1 on the 04 zx10r is the gear position N the unrestricted gear ?
Q2 looking at the wiring diagram and ohms readings ( page electrical systems 16-99 )if it is neutral can i not just cut the wire in conector position 2 & 3 and use a jumper wire to earth these thus fooling the ecu int thinking no resistance must mean the bike is in neutral ? ??
Thanks
bigstutyler is offline
post #2 of 3 Old 07-19-2010, 09:01 PM
bluedevil's Avatar
Thanks
Please go introduce yourself in the Newbies section and get to learn the site.
As far as Q1 yes the Neutral Is the gear but I wouldn't call it unrestricted but helps for the on-off throttle response compared to other gears. There is NO performance/HP GAIN :headshake
Q2- The ECU does not look for a Resistance but a Voltage...the Voltage is in the manual the TRE bypasses all gears by doing 4.3v I believe(it's in the manual for exact value).....so to answer cutting wires will not work the ECU provides 5v to the gear selector and expects to see a CERTAIN voltage back based the the resistor values it passes and back....when your in a certain gear there is a voltage drop(resistors) and the ECU knows what gear your in depending on the Voltage.
bloo
bluedevil is offline
post #3 of 3 Old 07-28-2010, 03:47 PM
I would seriously just get Ivan's TRE.... took me longer to get to it than Install it
they are $45 shipped online. Increases the OS factor the first few min of riding tho...
zarky is offline
Tech Question - Coolant dlizzle8 Performance and Tech 12 07-09-2010 09:39 PM
Tech Question bkkninja Performance and Tech 11 03-26-2008 09:44 PM
Someone with Tech knowledge on HID's..AMP question hotstang46 The ZX-10R 8 05-25-2006 02:58 AM
Race Tech Spring Question luckz88 Performance and Tech 20 12-29-2005 03:33 PM
general tech question Ricci The Out House 0 05-17-2004 01:37 PM
