ZX10r INTERCOOLER!!!!! Add HP! - Kawasaki ZX-10R.net
post #1 of 13 Old 05-22-2007, 10:54 PM Thread Starter
For all the drag racers, It's called CryO2 check it out!
http://www.1tail.com/sa/c/CryO2.htm
http://www.cryo2.com/testimonials.asp
Suzuk1ki11a is offline
post #2 of 13 Old 05-23-2007, 02:45 AM Thread Starter
Anyone have any experience with this car or bike???????
post #3 of 13 Old 05-23-2007, 10:45 AM
Speed Freak
garth285's Avatar
They have been using these on cars with forced induction for a long time basically gets sprayed on the intercooler to help cool the charge of air down.
I saw they have a fuel cooler which that would be pretty decent cause cooler fuel is alwyas better. maybe somehtign real good for a drag bike or something.
I wish you could jsut run a small like fridge pump on the bike for that matter tho.
BTW you can make these very very easy.
garth285 is offline
post #4 of 13 Old 05-23-2007, 02:51 PM Thread Starter
Yeah they also have the intake bulb that goes in the intake tube. It's basically is a heat sink that supposedly cools down to -80 degrees, and lowers your intake temps 50 degrees. They have intake bulbs in 2.5in and 3in sizes. I'd like to see a bike setup and dynoed and see what kind of gains you'd get. 1tail.com sells them so someone must have utilized this system on a bike.
post #5 of 13 Old 05-24-2007, 09:38 AM
drkramm's Avatar
for how much drap you would have to put in there i can't really see it being usefull a turboed car would probably work really well with it on the intercooler but i really can't see that bulb doing too much to the bike specialy since we can't carry a 10lb bottle
"Once you've tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been and there you long to return."
drkramm is offline
post #6 of 13 Old 05-24-2007, 09:50 AM
drkramm's Avatar
whats that noise ?
oh thats my freon pump
drkramm is offline
post #7 of 13 Old 05-24-2007, 11:46 AM
Speed Freak
garth285's Avatar
Hey if i could make a really small one I defintly would, would be pretty awesome to have freezing cold fuel all the time.
garth285 is offline
post #8 of 13 Old 05-24-2007, 11:55 AM
drkramm's Avatar
could always do peltier cooling paste them on to the bottem of the tank or on to the fuel rail though the tank would seem to be the most efficient
they heat and cooling using voltage (conveniently 12vdc) they just take some current can get high depending on size
http://cgi.ebay.com/123Watt-Peltier-...QQcmdZViewItem
an idea of what im talking about they can get pretty cold
drkramm is offline
post #9 of 13 Old 05-25-2007, 02:24 AM Thread Starter
I wonder if this could be made to fit around a 2-3in alumium intake pipe? I've never heard of these things and it seems like they could be put to use in the automotive industry!
post #10 of 13 Old 05-25-2007, 09:21 AM
Speed Freak
garth285's Avatar
I did some research on these, they would be a great idea if they didnt generate so much heat them selves. on one side of that wafer you have a freezing cold side and on the other you have an extremely hot side so your generating heat that needs to be disapated. so kind of like making more heat just to get ride of some heat.
garth285 is offline
06 zx10r kickstand to 05 zx10r? Superbike1 The ZX-10R 6 01-26-2007 07:24 PM
04-05 zx10r and 06 zx10r tank the same? ketjr81 The ZX-10R 5 09-28-2006 02:10 PM
Baby zx10r and daddy zx10r tonyzx10r The ZX-10R 7 01-29-2005 09:28 AM
