zx10r clutch problems - Kawasaki ZX-10R.net
post #1 of 4 Old 08-24-2006, 10:41 AM Thread Starter
heres the deal-i just installed the new clutch same oem fibers and steels from kawasaki-had good clutch tension w/ old slipping clutch. put new clutch in just like the old one came out-exactly. w/9 steels and 9 fibers, including the chatter plate-exact replacement from kawi. now I have to clutch lever-
clutch is fully adjusted and i barely have any lever. took the bike apart 4 times and everything checks ok-called kawi and talked to a tech and they said it sounds right and i have replaced a million clutchs on bikes-
after i put it together the 4th time I had a perfect clutch w/ the perfect adjustment-I worked the lever a couple of times and heard a pop in the
clutch cover and it was back to no clutch lever and a full adjustment to get anything-filled the bike w/ oil and cranked bike a clutch is real noisy when lever is pulled
please advise it something needs to be lined up that i don't see in the service manal or what your opinion is... no one else seems to know what the problem is-trying to avoid bringing it to kawi
thanks
bush102 is offline
post #2 of 4 Old 08-24-2006, 11:03 AM
Big Daddy's Avatar
Images: 38
perhaps this section will help and
Big Daddy is offline
post #3 of 4 Old 08-24-2006, 11:12 AM
eric's Avatar
eric is offline
post #4 of 4 Old 08-25-2006, 02:09 PM Thread Starter
ok no prob I figured it out and everything works ok
bush102 is offline
Clutch problems poptart29620 Performance and Tech 7 09-27-2007 08:09 PM
clutch problems jarhead05 Performance and Tech 1 08-24-2006 11:27 AM
Clutch problems zx10razor The ZX-10R 2 04-26-2006 10:29 AM
clutch problems maybe? KDW Performance and Tech 7 09-27-2005 07:33 AM
Clutch problems Zxrider The ZX-10R 0 10-13-2004 07:33 PM
