Zx10 turbo question - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SpazOnaZX
post #1 of 9 Old 05-04-2019, 10:34 PM Thread Starter
Zx10 turbo question
Are the upper/secondary injectors on an 08 zz10 needed when I switch to turbo? Or can I just get bigger primaries?
DeeWayne is offline
post #2 of 9 Old 05-04-2019, 11:51 PM
michael4012's Avatar
There's a few regular members that can give you exacting advice on Turbo builds, but i presume your having difficulty with the airbox not allowing for a top rail?
michael4012 is offline
post #3 of 9 Old 05-07-2019, 12:23 AM
At high revs the secondary nozzles work more efficiently than the primary ones. Of course, if we are talking about high-performance motor.
max232 is offline
post #4 of 9 Old 05-07-2019, 11:29 AM
SpazOnaZX's Avatar
If you are using the stock ECU: must use all 8.
If you are using a stand-alone or previous generation ECU: bigger primaries only will work
gaz likes this.
SpazOnaZX is offline
post #5 of 9 Old 06-15-2019, 06:23 PM Thread Starter
Would my 08 run on an 07 or earlier ecu? I know it's very similar to the 07. Is there links anyone can post? Attempting to do research
DeeWayne is offline
post #6 of 9 Old 06-15-2019, 06:24 PM Thread Starter
Would my 08 run on an older ECU that u can just put big primaries in? Um assuming there are differences in the wiring harness and maybe some sensors are different
DeeWayne is offline
post #7 of 9 Old 06-15-2019, 06:26 PM Thread Starter
I am having difficulties with that. I'm getting the airbox custom made so i could have it made to accept the secondarues also but I'm trying to make it as simple as possible and cutting down on the amount of injectors helps
DeeWayne is offline
post #8 of 9 Old 06-16-2019, 01:04 AM
I am having difficulties with that. I'm getting the airbox custom made so i could have it made to accept the secondaries also but I'm trying to make it as simple as possible and cutting down on the amount of injectors helps
Absolutely better to have a secondary rail as the fuel delivery is much more efficient at high RPM the stock g3 ecu requires that rail! You can have larger injectors in top rail as the g3 ones are relatively small.
post #9 of 9 Old 06-16-2019, 09:07 AM Thread Starter
Nah I dont think I need to go bigger, I think the 8 injectors can flow enough fuel for 7psi from a little gt28 lol. I would go away from my current stock ecu if I could find an older stock ecu that only uses 4 injectors but I think I'll ultimately just get the top rail to fit.
DeeWayne is offline
04 zx10 turbo air filter question lildavis187 Performance and Tech 2 06-14-2010 09:21 AM
Attn turbo guys join the group "turbo-10r" hesaves0211 The Out House 4 02-11-2009 09:28 PM
turbo motor and turbo kit 04-05 dble r Parts, Gear and Accessories 13 09-28-2008 08:36 PM
muzzy turbo or velocity turbo turboten Performance and Tech 20 09-13-2006 10:47 AM
Suzuki Hayabusa Turbo vs. Dodge Viper GTS Twin-Turbo jb_motogp Pictures and Videos 0 08-03-2005 02:16 AM
