Gen 2: 2006-2007 zx10 2006 calipers - Kawasaki ZX-10R.net
post #1 of 8 Old 04-08-2012, 08:57 PM Thread Starter
zx10 2006 calipers
Hi, i saw a lot of posts of braking problem on zx10 06, i want fix this problem.i met a guy in road and he swap stock calipers to 2008 model (gen3). this is best solution? thanks
SpiN is offline
post #2 of 8 Old 04-08-2012, 09:42 PM
BigCat for Prez!
BigCat10R's Avatar
u can swap to the 3rd gen calipers or any yr zx14, 06-10 zx6r, and i belive 07-10 cbr1000 (with 5mm shims).
BigCat10R is offline
post #3 of 8 Old 04-08-2012, 09:50 PM
TexasRider's Avatar
Yup...what ^^ said
TexasRider is offline
post #4 of 8 Old 04-08-2012, 10:11 PM
Zx10EBONYZx10's Avatar
I just order mine from eBay cost me 175 + 15 shipping 08 ZX14 front full assembly I can't wait to put them on and feel the dif going to be a life saver that's for sure
Zx10EBONYZx10 is offline
post #5 of 8 Old 04-08-2012, 11:29 PM
Gen2 Ripper
neverendingmods's Avatar
I have gen3 Calipers on my 07. You MUST use 310mm front rotors or the pads will not touch the rotor completely. The gen3 Calipers sit further out on the fork mount. No spacers, its the opposite. Need bigger rotors and the gen3 rotors bolt right on a gen2 perfectly. Look at my signature at bottom of my post. I have gen3 tokico Calipers which are FANTASTIC. I have EBC XC Contour 310 mm prolite rotors. And I have Vesrah pads and stainless lines. The gen2 stainless lines work perfectly with the gen3 Calipers.
ID:	160234   Click image for larger version
neverendingmods is offline
post #6 of 8 Old 04-17-2012, 05:45 AM Thread Starter
humm very nice! thanks a lot for your help =)
SpiN is offline
post #7 of 8 Old 07-23-2012, 06:20 PM
so I picked up a set of gen 3 calipers for $85 shipped....I planned on new rotors, so if Im understanding correctley I need to buy 310mm gen 3 rotors and from the looks of yours the calipers still need to be milled slightly to fit perfect, so neverendingmods, does it look like 320mm rotors will fit right on, Brembo offers 320 for the bike
Lobo is offline
post #8 of 8 Old 07-24-2012, 01:38 PM
You should also consider getting that Brembo master cylinder.
I've got the 2006 CBR1000RR calipers, steel braided lines, and the Brembo master cylinder on the bike. That setup will safely bring her down from 150 to 0 with two fingers, never a moment of brake fade and very confident feel regardless of the situation.
That setup was installed after a track day where the brake system completely failed while attempting to decelerate before a corner. Didn't low side, but went off the coarse and into the dirt.
antaren is offline
2006 CBR1k Calipers hs1113 Parts, Gear and Accessories 6 05-31-2010 01:06 PM
2008 6r brake Calipers on 2006 zx10r lowkey420 The ZX-10R 5 05-05-2009 03:26 PM
2006 zx10r calipers sladkixxx The ZX-10R 3 04-24-2009 10:55 AM
2006 Honda CBR1000RR Calipers F/S CNI Dawg Parts, Gear and Accessories 16 04-04-2009 03:30 PM
2007 ZX-6r Master Cylinder + lever and reservoir, 2006 ZX10 Calipers 06Neenja Parts, Gear and Accessories 5 11-18-2007 08:43 AM
