ZX-14 injectors on a ZX-10 - Kawasaki ZX-10R.net
post #1 of 6 Old 08-03-2008, 11:50 AM Thread Starter
I'm gonna try switching to E85 and if i need bigger injectors i'd like to try the 14's. If they are bigger or even will plug in. Has anyone tried or seen if they will work with the 10's rails and plug-ins? Thanks.
DethsZX10 is offline
post #2 of 6 Old 08-03-2008, 12:38 PM Thread Starter
Damn i just looked up the part #'s and there the same for both bikes. There goes that idea.
post #3 of 6 Old 08-03-2008, 01:26 PM
Azzkker's Avatar
e85 will kill a fuel system not designed to run on strait alcohol, methanol or ethanol. the e85 cars and trucks have special o-rings, gaskets, fuel lines and injectors to handle the extra abuse e85 brings with it. plus it takes more e85 to move the same distance so your mpg will fall and you will aways be on the gas station hunting mode.
Azzkker is offline
post #4 of 6 Old 08-03-2008, 02:48 PM
Nukedog's Avatar
All you had to do is increase fuel pressure by 12 - 14 psi..
09 R6S Slow and steady...
USN Retired *1987-2007*
IYAOYAS
Nukedog is offline
post #5 of 6 Old 08-03-2008, 04:19 PM Thread Starter
E85 has its performance benefits. I will dyno it on the 110 tune and the E85 tune after the conversion.
post #6 of 6 Old 08-03-2008, 04:26 PM
ninjafan2's Avatar
Keep us posted
ninjafan2 is offline
injectors redline659 Performance and Tech 9 06-02-2008 09:00 AM
zx-10R injectors KIRK_ADAMS Wanted: Buy or Trade 2 05-08-2008 08:09 PM
injectors?? zx-sik-r Performance and Tech 11 04-29-2008 11:57 AM
injectors sweetride10r Wanted: Buy or Trade 4 11-26-2007 08:30 AM
Servo On The Injectors? Cody Borders Performance and Tech 3 09-08-2005 11:09 PM
