Gen 3: 2008-2010 zx-10R shifting issue - Kawasaki ZX-10R.net
post #1 of 46 Old 03-30-2013, 10:54 PM Thread Starter
I'm having some issues shifting my 09 zx-10 r.... I come off of the throttle and try to up shift with no success... I really have to be forceful to get the gear to change most of the time. Any adjustments I can make to help this out? Maybe a change in oil?
Really killed me today bouncing off the rev limiter in 2nd more then once
When I use the clutch its much easier... Maybe its just me but my cbr's and gsxr's all shifted soooo much smoother.. Maybe just he bike?
p00hbear is offline
post #2 of 46 Old 03-30-2013, 11:08 PM
Gunny's Avatar
i know the 08s had a problem with a bad shift shaft that whould make it really hard to shift from second to third and what not. maybe that.
Gunny is offline
post #3 of 46 Old 03-30-2013, 11:23 PM Thread Starter
I hope not :-/ ... It does seam to be dominate in the 2nd to 3rd though... Any other ways to diagnose it?
p00hbear is offline
post #4 of 46 Old 03-30-2013, 11:26 PM Thread Starter
Mine is an 09 btw... IDK if there was a bleed over from the 08's
p00hbear is offline
post #5 of 46 Old 03-31-2013, 05:53 AM
theatiss's Avatar
i have noticed an issue on downsifting from 3 to 2...but i change thelever comp with the 2010model and its better...p/n 13161-0073
theatiss is offline
post #6 of 46 Old 03-31-2013, 08:06 AM
den33's Avatar
My 08 shifts like a hot knife running through butter at almost 12000 miles. How many miles on your bike?
den33 is offline
post #7 of 46 Old 03-31-2013, 08:42 AM
SkyDork's Avatar
Ummmm....so let me get this straight. This problem only happens when you're trying to CLUTCHLESS shift? That would be handy to know. Likely you've damaged tranny parts trying to force it into gear without the clutch. That's why it's hard to shift when not using the clutch. Start shifting with the clutch!
#WordCrimes
SkyDork is offline
post #8 of 46 Old 03-31-2013, 08:48 AM
What is the deal with the bad shift shaft on the gen 3's? I have never heard of this. Is there a new part number for a replacement shaft? Thanks. Mike.
880turbo is offline
post #9 of 46 Old 03-31-2013, 09:01 AM
Definitely get the the new beefier upgraded shift shaft. Your problems will go away. Around $100 in parts. Pretty easy to replace.
Sent from Motorcycle.com App
grassman2852 is offline
post #10 of 46 Old 03-31-2013, 09:04 AM
SkyDork's Avatar
He has an '09! He already has the new design shaft. That isn't the issue!!!
#WordCrimes
SkyDork is offline
Gen 3 Shifting Issue Proteus The ZX-10R 8 06-05-2011 12:07 PM
06 10r hard shifting kawiboytwo Performance and Tech 1 05-04-2010 03:04 PM
Unique Shifting Issue? jblaze Performance and Tech 3 03-08-2009 03:22 AM
shifting issue.... pmaf1 The ZX-10R 6 11-13-2007 09:29 PM
Shifting to first (06 10R) YZF The ZX-10R 17 05-09-2006 10:51 PM
