Zx-10r 2004 wouldn't like to start - Kawasaki ZX-10R.net
post #1 of 8 Old 08-13-2015, 03:01 PM Thread Starter
Well I put out throttle body to adjust TPS and I do fine all in spec in the right place now.
So I replug all the connections and.....bike don't want to start. Make fire, so I put little drop of gas in the throttle body holes, and yes it start, for little while.
So possibly injectors or misconnect something don't let the injector to work ??????
Can't see if their any wire un pluged ?
There's no error code at all (you know the self diagnosis test....).
The fuel pump work fine and lots of pressure.
So really I don't understand a thing.
Oh yes there's a PCIII hook to the grey connectors where it should be.
I got another throttle body in good shape, so maybe ĢI will swap it and see if it resolve the problem but I doubt...
Any clue ?
ninja_12r2000 is offline
post #2 of 8 Old 08-14-2015, 12:15 AM
bluedevil's Avatar
Just to be sure remove the PCIII anyway even if it is connected right.
Also if your Idle adjustment screw or fast idle screw is messed up(maybe wrong position) that may give a symptom of no start since you say it starts with throttle body spray only....also and very common is Fouled plugs.
bloo
bluedevil is offline
post #3 of 8 Old 08-14-2015, 10:38 AM Thread Starter
I will try to unplugued the PCIII and see what's happen.
Tonight will be the test.
post #4 of 8 Old 08-14-2015, 06:56 PM Thread Starter
Pc III are done so is that can be repair ???? Or i need another one?????? Any. Pc III USB around ????,
post #5 of 8 Old 08-15-2015, 02:13 AM
bluedevil's Avatar
bloo
Just to be clear your PCIII WAS THE PROBLEM CORRECT?
Meaning your bike starts just fine now right?
Sorry to state the obvious but you always ask for help on this site want it to be clear others in the Future get Clear Information on your fix if it applies.
thanks,
bloo
post #6 of 8 Old 08-15-2015, 10:17 PM Thread Starter
Yep PCIII is out of order.
Was working until I readjust the TPS. After that niet, even if I plugged the 9 volts adaptor.
post #7 of 8 Old 08-17-2015, 09:04 PM Thread Starter
Well and that freak me up the PC III just begin to work again? I just put out the PC III out of the bike and it sit on the table. So i decided to plug the 9 volt volts adaptor and it work fine even the map i loaded recently still there. So really ? Is that because i unpluged the bike battery ? Or I just call it a miracle?
post #8 of 8 Old 08-17-2015, 10:24 PM
bluedevil's Avatar
Loose connection on power somewhere or your just going to have to send it into Dynojet.....I had the opposite one time on my PCIII would power up fine on the bike not with Battery...Got into a little Tif with the Tech at Dynojet he said my PCIII was toast because he couldn't power it up on the bench....I said so what that doesn't mean it's toast it came from a fully functional bike, and fast too. ...in the end I wanted the firmware upgraded and that can only be done on the bench if old enough so took Dynojets offer for a New PCV for only $220 but you have to surrender your PCIII first.
bloo
I swore I wouldn't...but photodigm1 The Out House 579 04-17-2017 10:12 PM
2004 ZX10 Won't Start anaxagoras1986 Performance and Tech 40 06-11-2013 08:57 PM
Why wouldn't you wear earplugs? greg 0410r/6rr General Motorcycle Discussions 55 06-21-2009 10:41 PM
I wouldn't mind going to a game. JazzMan The Out House 9 05-29-2009 01:53 AM
Wouldn't This Suck axo250 Pictures and Videos 11 03-08-2008 10:12 AM
