yet another brembo mc question - Kawasaki ZX-10R.net
post #1 of 7 Old 03-30-2006, 08:34 PM Thread Starter
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
finally got my brembo and have searched old threads for an hour,i need some advice please.1st, i got the brembo resivoir,anyone got a quick and effective mount or should i bin it and use the stocker(any feel differences between the 2?)i bent the stock res. mounting bracket down and can make it work like a true coon-ass but the res. sits fairly low in relationship to the lever ass.doesn't the res. need to be higher than the lever ass.?2nd any one runnin goodrige hoses?Brad @ Superbike Supply had em in stock so thats what i ordered,will the banjo angles work?thanks for any help from the guys already runnin this set up.
SUPER K is offline
post #2 of 7 Old 03-31-2006, 12:39 AM
Which Brembo res? There are many types. If you got the same as I did, it comes with a metal cylinder that is ~1/2" tall with a large hole at top and small hole at bottom.
I just removed the stock bracket and slightly filed the OEM screw head down a little so it would slip inside the cylinder to mount it directly to the triple-clamp. Leaves the res on a little bit of an angle, but works good.
If you have the same res and this doesn't make sense, lemme know & I can post a pic.
CanyonCarver is offline
post #3 of 7 Old 04-01-2006, 11:11 AM Thread Starter
Chickenstrip Eater
SUPER K's Avatar
got a plastic brembo res. the mount runs 90 deg from the side of the res., i think i'll just use the stocker 4 now thanks
SUPER K is offline
post #4 of 7 Old 04-01-2006, 04:03 PM
Sounds like your res is different than mine, anyhow.
post #5 of 7 Old 04-05-2006, 05:33 PM
CanyonCarver what part of SoCal r u from?
Risdog is offline
post #6 of 7 Old 04-05-2006, 05:45 PM
Rspec99's Avatar
Images: 11
I also got the Brembo reservoir but ended up using the stock one as I did not see a benefit and had to fabricate a new mount.
No problems....so far!
Rspec99 is offline
post #7 of 7 Old 04-05-2006, 08:56 PM
Ventura county.
636 m/c vs. brembo m/c.... latdrop Performance and Tech 17 04-01-2006 08:42 AM
Brembo Tech Notes - Fluid, Bleeding, etc. CanyonCarver Performance and Tech 3 03-06-2006 09:23 AM
Just ordered the Brembo Master cylinder kit and lines MDZX10 Performance and Tech 16 01-29-2006 10:08 AM
Brembo MC: Which Brake Light Switch? Tito Performance and Tech 5 12-30-2005 01:48 PM
Brembo Radial MC and Galfer 41ants Performance and Tech 5 04-29-2005 07:35 AM
