X-TRE: my thoughts - Kawasaki ZX-10R.net
post #1 of 18 Old 12-06-2008, 11:38 PM Thread Starter
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
X-TRE: my thoughts
I"ll be installing this tomorrow (Sunday) and will have some detailed thoughts about the mod. I have logged over 8,000 miles on the bike in stock trim, so needless to say, my butt is pretty calibrated to the stock performance and I should be able to detect a difference in power delivery in the lower RPMs.
In the meanwhile, before anyone puts up a sign, here are some of the bike being prepped for install tomm. Oh, i also be putting in a BMC race air filter!
Bike being prepped
Poser shot of 10r's stable mate
What my stock looked like.
XTRE thoughts coming tomm!
spikespiegel is offline
post #2 of 18 Old 12-06-2008, 11:41 PM
bluedevil's Avatar
your going to see a diff. with the NEW Filter alone so your results will be skewed
bluedevil is offline
post #3 of 18 Old 12-06-2008, 11:45 PM Thread Starter
lmao i was thinking that too hahaha
post #4 of 18 Old 12-06-2008, 11:49 PM
Postwhore with an 04
bcm0018's Avatar
Sweet but unfortunately I can't stop drooling over the MV!!
bcm0018 is offline
post #5 of 18 Old 12-06-2008, 11:54 PM
bluedevil's Avatar
...and I just don't say that blindly. I had a slip-on with stock dirty filter and when I replaced it with a BMC street actually gained 5hp...although a week apart on the dyno it was the same conditions and Dyno plus time of day, and same operator and I did feel the extra if that's possible once I had that combo meaning a clean Filter and a Slip-on.
bloo
post #6 of 18 Old 12-07-2008, 11:32 AM
any update spiegel
Alexsv is offline
post #7 of 18 Old 12-07-2008, 05:48 PM Thread Starter
ok so i installed the TRE and that was a success; i only tried the hard setting in 6th gear; I went on a 5 min jaunt in 40 degree weather so I didn't want to push going fast or anything right out of the neighborhood. Overall, in partial throttle, it does seem like its got a bit more oomph ; its nothing overwhelming where the surge of power is gonna kill you; it just seems like its a bit more willing to haul. When I get out in the twisties on a proper day, i'll be able to evaluate it further... If you got a spare 100 something bucks, it can't hurt, but i dont feel like its a MUST DO mod...
post #8 of 18 Old 12-08-2008, 07:25 AM
Vanilla's Avatar
Well, where are the install pics???
Light travels faster than sound. This is why some people appear bright until you hear them speak!!!
Moderation in all things. Including moderation...Petronius
Vanilla is offline
post #9 of 18 Old 12-08-2008, 12:41 PM
hraponte's Avatar
I installed the X-TRE last weekend and went for a long ride. I'm good on turns and after 1000 miles on the ussual roads I got used to the bike. After installing the TRE set on hard, I had some trouble with throttle control in the turns. I took a couple minutes to set it to soft, and for my style of riding it worked better. In my opinion, hard is a good setting for drag racing. Installation was easy, 30-45 minutes.
DB Screen, ASV Levers, PCIII, Yoshimura R-77 Slip-on, Front/Rear Galfer SBK Steel Braided brake lines, Nissin Calipers, Solo Seat Cowl, Fender Eliminator, Integrated tail light, K&N Filter, Anodized red oil/brake caps, Yosh bar ends, modded damper, rim tape, X-TRE, HID light (right side), Aluminum radiator fan, Fork/Frame/Swingarm sliders, 1/5th throttle
hraponte is offline
post #10 of 18 Old 12-08-2008, 01:21 PM Thread Starter
unfortunately, as the instructions call for splicing wires from the ECU, i was too pre-occupied with that and forgot to take pics LOL.
The weather is not good enough to ride for me and i haven't had a chance to do a proper outing so i can't comment as to whether 6th gear setting makes it twitchy or not.. I def think that the hard setting makes partial response act more responsive and powerful, i'll be doing some back to back tests with the TRE off and in Hard mode when the weather clears up
Tags
x-tre
My 07 thoughts of 08 1bad10r Performance and Tech 14 02-02-2008 07:57 AM
Thoughts??? coletrane811 Pictures and Videos 19 11-23-2007 07:59 PM
thoughts on the 07 key... Pilot143 The ZX-10R 16 01-23-2007 01:04 AM
thoughts ninja2k5 The Out House 7 05-16-2006 07:45 PM
My WSB thoughts..... king-tony Race and Stunt 9 05-31-2005 12:33 AM
