WTF- this should start a debate!!! - Kawasaki ZX-10R.net
post #1 of 7 Old 07-26-2008, 04:16 PM Thread Starter
I just got my 04 10r dyno tuned and the print out showed 127.4 saehp and 65.2 saetrq @11600rpm. they run a superflow dyno and the tuner tells me its more accurate than a Dyno-jet Dyno(generally 30% lower), I have never seen numbers this low before, are they real world or did he make an error somewhere. I understand that there are factors to correct for HP losses (gear box,ratio,chain etc.) but why have I never seen a number published as low as this. To the tuners credit, they did show an increase in HP and Tourque , and the A/F line(12.6 av.) was flattened out quite nice. the bike runs very smooth and pulls like a freight train but sure would like a compareable reading. anyone have an anwser for this or can shed some technical light.
supperdaddy is offline
post #2 of 7 Old 07-26-2008, 04:58 PM
Weird, I've heard of superflow errors but generally they're higher than dynojet results.
NoodleArms is offline
post #3 of 7 Old 07-26-2008, 05:00 PM
.net Most Followed Member
luis.pita's Avatar
yeah and
luis.pita is offline
post #4 of 7 Old 07-26-2008, 05:02 PM
Post Whore
Older Guy's Avatar
Nah...I was 167 HP on the Dunojet with the Kit ECU...
And 135 HP and 152 HP with the Bazzaz on the Superflow WinDyn V2.7
Older Guy is offline
post #5 of 7 Old 07-26-2008, 05:07 PM
Originally Posted by luis.pita View Post
yeah and
thank you, and not to mention the protracted battle between dynojet and the rest of the dyno industry
post #6 of 7 Old 07-29-2008, 03:16 AM
10R Joe's Avatar
Images: 9
Thats some good info!!! Thanks. I had mine done & it was 136HP stock...never bothered going to a diff city to run on the other type of dyno...but the guy said with a custom map, PC3, A/F & pipe he could give me 10 more HP. $250 for the map...
If its got tits or tires it'll give u problems
10R Joe is offline
post #7 of 7 Old 07-30-2008, 04:31 AM
Nukedog's Avatar
Superflow dyno reads like an EC997 which is about 14% lower than a dynojet...
09 R6S Slow and steady...
USN Retired *1987-2007*
IYAOYAS
Nukedog is offline
Ron Paul wins Tuesdays Republican debate by massive landslide Sands The Out House 35 02-21-2010 03:15 PM
The Great OEM ZX-10R ZX-6R ZX-14 Front Caliper Debate. cbxfixer Performance and Tech 60 10-25-2009 06:01 AM
Helmet Debate silversv1k General Motorcycle Discussions 20 01-02-2008 03:18 AM
Ron Paul in the republican debate... Sands The Out House 2 05-05-2007 09:15 AM
gixxer.com debate on k5 v's zx10r Marko Rossi The Out House 18 04-14-2006 04:24 PM
