Would 07 w. 17t/42t need new chain? - Kawasaki ZX-10R.net
post #1 of 11 Old 04-15-2008, 12:25 AM Thread Starter
BrandensDogs's Avatar
Any advice is appreciated
If I only wanted to replace my rear sprocket (primarily for unsprung weight and little more umph off the line) on my new 07 could I keep my stock chain? And what about with a -1 front and + rear? Could I still keep the chain?
I don't have many miles on it yet (weather has been horrible and uncooperative) so the chain will would be getting "used to" the AFAM or something sprocket at 42t in place of the stock 40t.
Thanks, Branden
BrandensDogs is offline
post #2 of 11 Old 04-15-2008, 01:32 AM
WTtoolman's Avatar
I'd say the +2 or -1/+2 rear probably won't fit if it's a newer, low milage chain. I'd just go with the -1 front sprocket.
WTtoolman is offline
post #3 of 11 Old 04-15-2008, 03:44 AM Thread Starter
Just the -1 front and keep the stock chain and rear sprocket size? I believe I have read about people posting about aftermarket front sprockets being noisy? Is this true? Thanks again for bearing with my questions :)
post #4 of 11 Old 04-15-2008, 03:51 AM
silversv1k's Avatar
Images: 44
some can be noisy but get a stock 16t off a z1000 and you'll have nothing to worry about
silversv1k is offline
post #5 of 11 Old 04-15-2008, 04:14 AM Thread Starter
So keep the OEM chain right? Any suggestions where to pick up a Z1000 front sprocket? Just order it from a parts place I guess?
post #6 of 11 Old 04-15-2008, 04:16 AM
silversv1k's Avatar
Images: 44
www.ronayers.com will probably be your best bet
post #7 of 11 Old 04-15-2008, 04:23 AM Thread Starter
Awesome, thanks for the tip. I am assuming you agree that the stock chain will be fine?
post #8 of 11 Old 04-15-2008, 04:32 AM
silversv1k's Avatar
Images: 44
you should be good to go
post #9 of 11 Old 04-15-2008, 05:37 AM
Big Daddy's Avatar
Images: 38
^^ nice work
Big Daddy is offline
post #10 of 11 Old 04-15-2008, 05:46 AM
silversv1k's Avatar
Images: 44
Originally Posted by Big Daddy View Post
^^ nice work
i learn from the best
FS: New DID VM2 520 chain 2fast10 Parts, Gear and Accessories 0 11-30-2007 05:22 PM
Need new chain... Older Guy The ZX-10R 15 12-28-2006 12:07 PM
help chain and sprockets which ones are the best also a chain breaker streetfighter Performance and Tech 19 11-09-2006 06:31 PM
530 chain rocketracermike Performance and Tech 18 12-11-2005 06:21 AM
Chain Help! DB's ZX10R Performance and Tech 19 06-21-2005 10:55 AM
