Woolich Throttle map - Page 4 - Kawasaki ZX-10R.net
 2Likes
post #31 of 44 Old 05-08-2019, 10:09 AM Thread Starter
Got it.
Now that I've spent a little time with the Woolich software I'm starting to get the hang of it. I've learned how to use the Autotune and I'd say I'm about 90% of the way to a really good fuel map. Once I get it completely ironed out I will do a map share on Woolich's web site.
Sent from my SM-G935R4 using Tapatalk
Bloose is offline
post #32 of 44 Old 05-08-2019, 11:42 AM
I think I'm going to pull the IAP and TPS maps from a mapshare file to get started and autotune from there.
palomartian is offline
post #33 of 44 Old 05-09-2019, 03:23 AM
In your motorcycle, the maximum capacity is limited on all gears. Including the 6th gear.
In circled in red should be 100%
If you change to 100%, you will need to carry out a correction in these areas of the ignition and fuel maps
max232 is offline
post #34 of 44 Old 05-09-2019, 10:29 AM
Victors's Avatar
Originally Posted by Bloose View Post
Went to the dyno last night. My plan was to dial in the tune before hitting the track this weekend. I did get to do some tuning but in reality the dyno is mostly good for WOT. I will do my best to let the Autotune work its magic during practice on Saturday.
With just a little Autotuning, which included opening up the ETC at high rpm and WOT, this is my dyno result.
Bike specs are
2019
K&N race filter
Slip on with decat
No exhaust or intake flap
AIR blocked off.
What air/fuel ratio did you end up at after tuning?
2013 10R
2007 650R
2016 10R
Victors is offline
post #35 of 44 Old 05-09-2019, 08:09 PM
There are no ignition or fuel map differences in the EU map. Only the de-restriction of the ETV map. At least not in the 2018 maps I accessed in the included Woolich bin files.
post #36 of 44 Old 05-10-2019, 01:59 AM
No need to take EU maps as a reference.
At the dyno can be easily improved.
Of course noise will increase, CO will increase.
max232 is offline
post #37 of 44 Old 05-10-2019, 10:37 AM
Agreed. It can always be better. I read your post as implying there would be negative consequences to changing the ETV maps without adjusting other parameters. Just pointing out there is no basis for that assertion in Kawasaki's stock mapping. I might argue the opposite. That the ETV is out of whack on the US models, and changing the ETV to Euro spec puts fuel and ignition maps closer to optimum. It's just speculation though. As you say, without a proper tune we're still stuck with a map engineered to meet noise and emissions regulations, not optimize performance. When I'm done with my build I'll have 40lbs of middle finger to regulation sitting in a box in my garage. I must not be "woke."
post #38 of 44 Old 05-28-2019, 05:05 PM
Your bike looks great! You still had the CBR last year when we did the Advanced Basics 301 course at Blackhawk Farms. We had Jody Berry as our coach. I had the black 2016 zx-10r. Jason Farrell was there that day and he convinced me to let him work with my Woolich to tune it. He changed all the ETV settings to 100 and worked on the low rpm fueling. It was terrible before, now much better. I've got a link pipe, stock muffler, bmc air filter, sai blockoffs, and run pump premium fuel. He said it made 181 at the tire.
ladwign is offline
post #39 of 44 Old 06-06-2019, 01:34 PM Thread Starter
I wish I could say I remember who you were but Iím old.
If you race CCS at all stop in and say hello, otherwise maybe at a track day.
We put mine on the Dyno and made 195 RWHP before I figured out 100% how to use the Woolich. After the dyno time I let it Auto Tune for an entire day of practice at ACC. I loaded that map and it runs great. Not sure exactly what the HP is now but Iíd say a minimum of 195. Runs good at low, mid, and high RPM as well as at idle.
Hope to see you at the track!
Bloose is offline
post #40 of 44 Old 06-09-2019, 11:03 PM
You bet! I'm thinking about doing the CCS weekend this month, but we'll see. Are you running race fuel to get 193hp?
ladwign is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Gen5 woolich map Nellybus Performance and Tech 9 06-19-2016 01:19 AM
Woolich map michael4012 Performance and Tech 13 02-19-2016 07:23 AM
Gen 1: Map map mappity map MrMoto73 Performance and Tech 0 09-30-2014 06:13 AM
Gen 2: Need help with map selection, Woolich flash, and other tuning probs. sweetfa65 The ZX-10R 0 05-26-2014 01:29 AM
Woolich racing stp map miker1 Performance and Tech 2 07-10-2013 08:14 PM
