Gen 2: 2006-2007 Woodcraft stator cover & OEM clip-on questions - Kawasaki ZX-10R.net
post #1 of 5 Old 08-10-2014, 10:11 PM Thread Starter
mishanja's Avatar
Have question about couple of mods on my Gen 2.
So, today I went to install Woodcraft stator cover, and run into the issue with wiring coming into cover. On the first picture, is OEM cover. Wiring in question is white wires coming in from the top. In OEM cover, there is a rubber gromet around wires, but also it is encapsulated by metal cover. On Woodcraft, the same area is hollow, so the wire can be just placed in it. My question, is cutting metal piece on OEM is the only way to get wires out?
I want to install lever guards like these:
However, when I looked at my OEM clip-ons, I saw that they are not hollow. Is it possible to install the lever guards?
mishanja is offline
post #2 of 5 Old 08-10-2014, 10:24 PM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
You should be able to wedge it out... You might have to remove the pins from the connector and fish them through. I don't have a gen4, just going by what I see.
Bear Jew
Hernando is offline
post #3 of 5 Old 08-10-2014, 10:24 PM
Crash Test Dummy
Hernando's Avatar
You sure the gaskets off....
Bear Jew
Hernando is offline
post #4 of 5 Old 08-10-2014, 10:26 PM Thread Starter
mishanja's Avatar
i'll double check, thank you
mishanja is offline
post #5 of 5 Old 08-17-2014, 06:35 AM
tasos's Avatar
The metal cover is the gasket. You need a new one with the woodcraft, or reuse the old one after carefully removing it.
tasos is offline
06-10 woodcraft stator cover jmsmith37 Parts, Gear and Accessories 5 02-11-2014 07:55 AM
Gen 2: I need stator cover & right side starter cover Zx10EBONYZx10 Wanted: Buy or Trade 1 12-01-2012 12:51 AM
GSXR woodcraft stator cover.. codyc_13 Parts, Gear and Accessories 0 02-04-2011 10:06 PM
3rd Gen. Woodcraft stator cover (left side) TENN10 Parts, Gear and Accessories 8 10-13-2010 10:08 AM
clip ons, stator cover, ohlins clip on mount ninja_zx14 Wanted: Buy or Trade 6 05-15-2009 06:26 PM
