wont power-on?! - Kawasaki ZX-10R.net
post #1 of 6 Old 08-10-2010, 09:06 PM Thread Starter
inappropriate
hesaves0211's Avatar
Images: 67
wont power-on?!
didnt ride the bike for a good period of time. it started just fine after i unloaded it from my truck (since i moved). i parked it behind my house where i accidentally placed the key to "park" instead of lock. went to dinner and in that time a huge rain storm struck. returned home and the poor thing was drenched, the first its seen rain like this---was not my intentions to let it see rain. so it wouldnt power-on, no dash response, nothing, dead. i tried jumping it but it wouldnt even start w the cables. for the heck of it i replaced the batt, and still no luck. any advice? ignition damage?
hesaves0211 is offline
post #2 of 6 Old 08-10-2010, 09:48 PM
dirt ninja's Avatar
Images: 9
I would start by checking fuses.
dirt ninja is offline
post #3 of 6 Old 08-10-2010, 11:50 PM
Tee's Kawa55's Avatar
Originally Posted by dirt ninja View Post
i would start by checking fuses.
Tee's Kawa55 is offline
post #4 of 6 Old 08-11-2010, 08:25 PM Thread Starter
inappropriate
Images: 67
That was the first thing I checked (the ones under the seat)
post #5 of 6 Old 08-11-2010, 08:40 PM
Sebastian1000's Avatar
Still awaiting advice? Start pulling her apart? If it is completely dead, I would look for water accumulation/bad electrical connections/etc. I would also take a good look at the cluster...what happens if she sits out in the heat? Still nothing? Maybe if she is dry again, you might be in luck?
I don't know what to tell ya man. Good luck and hopefully someone else will chime in with some experience in this area.
Sebastian1000 is offline
post #6 of 6 Old 08-11-2010, 09:16 PM
Kawboy1056's Avatar
Tear that windshield and upper fairing off man and get it to where you can easily access the wiring harness behind your gauge cluster and see if that thing has signs of H2O. If so, it may have burnt up some relays. Take a look on Kawi's website or your Service Manual and see where they all are and just use the process of elimination. Can't see it being anything else. If that harness plug gets the slightest bit loose on the back of your gauge cluster, she won't do squat..
Kawboy1056 is offline
Bike lost all power, wont start NOMIEZVR4 The ZX-10R 20 09-06-2007 12:16 AM
help: pc3 wont power up! hesaves0211 Performance and Tech 18 05-31-2007 04:40 PM
help power commander issues wont run properly red fi light is on streetfighter Performance and Tech 17 11-12-2006 02:56 PM
