will the stock damper off the 06/07 zx10's work with the 04/05s? - Kawasaki ZX-10R.net
post #1 of 5 Old 01-17-2008, 09:56 PM Thread Starter
just curious, i might be able to pick 1 of those stock ohlins dampers for pretty cheap?
FlatBlackZX is offline
post #2 of 5 Old 01-17-2008, 10:05 PM
I thinks so. Not positive.
vjhils is offline
post #3 of 5 Old 01-18-2008, 01:30 AM
ducatiryder89's Avatar
Images: 21
You don't want the 06 stock unit. They blow seals like crazy. Remember that its the OEM Japanese Ohlins not the true Ohlins we come to praise.
ducatiryder89 is offline
post #4 of 5 Old 01-18-2008, 02:20 AM
bkkninja's Avatar
I thrown mine in the bin.
bkkninja is offline
post #5 of 5 Old 01-18-2008, 02:28 AM
CB160's Avatar
the internals are not the same as the Ohlins "aftermarket' dampers...(per Ohlins shop out here) get an aftermarket or have an OEM rebullt for $150.....(check out Kyles Racing)
CB160 is offline
stock 06-07 damper imbob05 Parts, Gear and Accessories 0 10-13-2007 01:00 AM
04 Stock body work treyzx10r Parts, Gear and Accessories 31 05-12-2007 07:49 PM
Will a stock 06 steering damper fit an 05 2005ZX10 The ZX-10R 1 05-10-2007 12:16 PM
Stock Ohlins Damper 06/07 martian Parts, Gear and Accessories 27 03-14-2007 06:47 PM
Will 40 tooth sprocket work with stock chain? zx10Rocket Performance and Tech 8 03-09-2006 08:31 PM
