Gen 2: 2006-2007 Will Gen 3 Front Forks Inners fit my Gen 2 - Kawasaki ZX-10R.net
post #1 of 6 Old 05-08-2011, 04:38 AM Thread Starter
Late Apex
Solo-Six's Avatar
Was wondering if the inners ie. fork caps, rebound push rod, entire inside assembly fit inside my 2007 gen 2 tubes ? just changed my seals and didnt properly set one seal so i have to re do it . Was thinking since i am there i would upgrade the guts and have the titanium look cap instead of my red one which is fading due to sun exposure
Anyone have any information or can confirm this change will woork would be great .. I dont have the coin for Cartridge kits or upgrading beyond what I am hoping will work ..
If this will not work ... the slide tube that compresses the spring could i replace that plastic tube with a longer one on both sides to increase spring rate and compensate it with less rebound and compression or am i headed in the wrong direction in this thought process
________________Grip It And Rip It_________________
Solo-Six is offline
post #2 of 6 Old 05-09-2011, 10:00 AM Thread Starter
Late Apex
Solo-Six's Avatar
All you SELF PROCLAIMED Race Junkies and World record setting MOTOGP racers and no one has a cross reference yay or nay for me .... how interesting
Solo-Six is offline
post #3 of 6 Old 05-09-2011, 10:16 AM
flthy1's Avatar
Sorry man, I don't know if they'd fit but you could check the diameters in the race manuals to see. But won't you spend 3-400 on a set of Gen 3 forks? You can buy full race tech internals for that if you don't mind a little work. With gold valves and the right spring rate they should be much better than a stock Gen 3 fork would be
flthy1 is offline
post #4 of 6 Old 05-09-2011, 10:25 AM Thread Starter
Late Apex
Solo-Six's Avatar
got a link for that kit .. and i have a bead on those inners for 60.00
define ... work .. i cant fab nothin for suspension . i have limited resources in that area
Solo-Six is offline
post #5 of 6 Old 05-09-2011, 10:49 AM
flthy1's Avatar
I don't have a link, I just ordered mine through 303 cycle, 1 of our sponsors here. Check with 9r to 10r, I know he has Gen 3 ohlins forks in his Gen 1, not sure if he has any insight on the stock internals but he's pretty techy with this stuff
flthy1 is offline
post #6 of 6 Old 05-14-2013, 03:55 PM
Cloud 9's Avatar
the fork tube plastic can be spaced ( lengthened but i wouldn't ).
the only thing you need is a heavier spring .
i have the same bike as you and looking for similar answers.
the gen 2 has 8.5 N/mm spring rate, too soft unless your a jockey.
you want a heavier spring which should be cheap where you are, the cartridge doesn't set the sag or weight carrying side of your front forks.
i can get springs here in aussie for about a 100 bucks so you should be able to get cheaper cause they come from there.
Cloud 9 is offline
WTB: 04-05 Inners and bracket italicizedsponge Wanted: Buy or Trade 2 05-05-2010 10:34 AM
08/09 front forks.... 5-F Dawg Parts, Gear and Accessories 1 10-18-2009 09:24 PM
04-05 front forks, calipers, front rim, tires RickRoush03 Parts, Gear and Accessories 7 10-05-2008 12:31 PM
Front forks freeflyer1 Performance and Tech 11 08-15-2008 03:54 AM
Does anyone know if the front forks can be swapped with forks from another model liljunglist2 The ZX-10R 2 02-04-2005 01:39 PM
