Will an 08 motor fit in a 06-07 - Kawasaki ZX-10R.net
post #1 of 15 Old 10-26-2008, 04:10 PM Thread Starter
Well I threw number four rod threw the block today at the strip. So that motor is trash. And that brings me to my next question. Will the 08 zx10r motor fit in a 06-07 frame? I don't mean bolt right up but will it fit with custom motor mounts?
Spillman is offline
post #2 of 15 Old 10-26-2008, 05:28 PM
MotoTech10R's Avatar
Dont know for sure but good luck with it man..
01 ZX6R - Sold
05 ZX6R 636 - Totaled(not by me!) and Rebuilt - Sold
2006 ZX10R - Riding every day
"Gear Nazi"
________________________
|^^^^^^^^^^^^^^^^^|*||__
|- TEAM MONSTER ENERGY -|*||'|";\,___.
|_..._..._by_Kawasaki______|*||_|_|...,]|
MotoTech10R is offline
post #3 of 15 Old 10-26-2008, 05:30 PM Thread Starter
Also another question. Is it worth the trouble to retrofit the 08 motor. Is there really that much of an improvement?
Spillman is offline
post #4 of 15 Old 10-26-2008, 06:07 PM
RussMcB's Avatar
I'm interested to hear, too. Someday I may want to put a later engine into my race car.
RussMcB
F1000 (SCCA Formula Car w/ '07 ZX-10R engine) - Sold in 2010 :-(
'99 ZRX1100
Marietta, GA USA
RussMcB is offline
post #5 of 15 Old 10-26-2008, 06:14 PM
Gone Ridin'
twidget's Avatar
Send a message via AIM to twidget Send a message via MSN to twidget Send a message via Yahoo to twidget
I don't know if it would be worth it or not. My gut says that the real improvements in the bike are in the handling, but if you need a new motor anyway, it may be worth the extra effort.
twidget is offline
post #6 of 15 Old 10-26-2008, 06:29 PM
Speed Freak
garth285's Avatar
if you can get one for the same price as a replacement motor or fixing the motor I'd say go for it, the only thing is that you will maybe have issues with the throttle bodies since they changed to oval TB's but they might have only made the intake boots different to fit. I'm sure it can be done but you also have to wonder about sensors and such....
garth285 is offline
post #7 of 15 Old 10-26-2008, 06:33 PM Thread Starter
I have several advanced electronics training classes under my belt. So wirring won't be an issue.
Spillman is offline
post #8 of 15 Old 10-26-2008, 06:39 PM
Speed Freak
garth285's Avatar
wiring and also the crank pickups are sometimes different but if they are the same you should be safe.
garth285 is offline
post #9 of 15 Old 10-26-2008, 07:08 PM
redline659's Avatar
Anything will fit with enough time, but the improvement wont be enough to warrant the cost in throwing in the newer motor
redline659 is offline
post #10 of 15 Old 10-26-2008, 07:20 PM
ZX-10R_Sinner's Avatar
Yeah, other than the added fuel injectors and oval sub throttle bodies, there isn't much difference. If you put the race intake cam kit and thinner head gasket you're running pretty much what the 08 is because it has the higher compression, and the cam specs on the stock 08 are pretty much the same as far as I know. I hope you're getting what I'm saying, basically that it'd be a waste of time/money. Build up an 06-07 motor and put in there, you're better off doing that IMO. The second set of injectors are really the only thing better on the 08's motor.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
06 Motor yamadak13 Parts, Gear and Accessories 6 03-01-2008 12:27 PM
Need a motor. ninjamaster6-10 ZX-7, ZX-7R & ZX-7RR Discussion 9 12-09-2007 09:52 PM
Motor Oil? 06BLK10 Performance and Tech 26 08-22-2007 05:39 PM
My next ZX-10R motor banzai Pictures and Videos 15 06-16-2006 06:32 PM
Motor is Out!!! Bobster The ZX-10R 26 04-26-2005 05:58 PM
