Wierd hesitation on takeoff. - Kawasaki ZX-10R.net
post #1 of 14 Old 08-01-2010, 07:07 AM Thread Starter
oxthegrunt's Avatar
Stutters from idle to 3500 RPM
So my wife and I rode to a friends house tonight. We stopped just before we got there to pick up some sodas. The gas station we stopped at was about 3-5 miles from their house a lot of uphill. When we got onto their road we were driving slow trying to figure out where it was. Riding the clutch it started to hesitate. When we left their house it was still doing it. When I take off I rev a little bit and slowly let the clutch out. It will start to go and the just bog down. It's only when taking off that I have the problem what do you think?
Last edited by oxthegrunt; 08-02-2010 at 10:39 PM. Reason: Better description of problem
oxthegrunt is offline
post #2 of 14 Old 08-01-2010, 08:11 AM
blake2032's Avatar
I just had the same problem, it would bog and sputter from like 2-4k rpm and the take off like no problem. It turned out to be the spark plugs. Not saying its your problem but might be a good place to start. Also check all of your ECU connections.
blake2032 is offline
post #3 of 14 Old 08-02-2010, 01:15 AM Thread Starter
oxthegrunt's Avatar
Wouldn't the plugs cause problems across the whole rev range? I think it might have something to do with the clutch?
"The OX"
post #4 of 14 Old 08-02-2010, 02:47 PM
blake2032's Avatar
thats what I thought too but It may not be a bad place to start anyhow.
post #5 of 14 Old 08-02-2010, 03:01 PM
rtaplin's Avatar
fuel pump maybe
rtaplin is offline
post #6 of 14 Old 08-02-2010, 03:05 PM Thread Starter
oxthegrunt's Avatar
I've ruled out the clutch. It bogs below 3000 rpm, but only while it's in gear.
"The OX"
post #7 of 14 Old 08-02-2010, 10:37 PM Thread Starter
oxthegrunt's Avatar
It's getting worse. I'm starting to notice that the problem is happening from idle to 3500 RPM's. It stutters really bad below 3500, but once it gets past 3500 it takes off like a rocket. At first I thought it had something to do with the clutch, but its happening while rolling in first also.
"The OX"
post #8 of 14 Old 08-05-2010, 11:52 AM
rtaplin's Avatar
Check out that fuel pump. It happened to my bike
rtaplin is offline
post #9 of 14 Old 08-05-2010, 12:03 PM
Slow Poke
bgmagma10's Avatar
if the fuel pump is going out it will get alot louder. least thats how mine went
bgmagma10 is offline
post #10 of 14 Old 08-05-2010, 12:05 PM
Omofo's Avatar
may be the exhaust or 2ndary butterfly servo?
Ignorance is the enemy, let's set the record straight. If history must repeat itself, why worry while you wait?- Rodney Crowell
Omofo is offline
Hesitation until 3K javeci01 Performance and Tech 21 07-25-2008 01:42 PM
FS: 1 set of pilot race takeoff's fstR1 Parts, Gear and Accessories 3 06-04-2008 01:28 PM
Ready for Takeoff Ken B Welcome Newbies! 14 02-17-2006 09:37 PM
FS: More Tires - Takeoff's Ara Parts, Gear and Accessories 1 07-27-2005 10:03 AM
Metzeler RS2 190 Rear Takeoff 02Silver Parts, Gear and Accessories 0 06-01-2005 09:53 AM
