Widest 200/50/17 Tire? - Kawasaki ZX-10R.net
post #1 of 22 Old 10-27-2008, 02:13 PM Thread Starter
What s widest tire on market in 200/50/17?
SAkI is offline
post #2 of 22 Old 10-27-2008, 02:53 PM
hraponte's Avatar
Sorry, but is this a trick question??? A 200/50/17 can only be 200mm wide.
The first three digits (200/) = width in mm. 200mm
The second digits (/50/)= profile or side wall height, but this number is a % of the width. In this case, the profile is 100mm.
The last digits (/17) = rim size in inches. 17in.
Based on your question, I assume you don't know how to read the tire numbers, therefore the above explanation.
Take care.
DB Screen, ASV Levers, PCIII, Yoshimura R-77 Slip-on, Front/Rear Galfer SBK Steel Braided brake lines, Nissin Calipers, Solo Seat Cowl, Fender Eliminator, Integrated tail light, K&N Filter, Anodized red oil/brake caps, Yosh bar ends, modded damper, rim tape, X-TRE, HID light (right side), Aluminum radiator fan, Fork/Frame/Swingarm sliders, 1/5th throttle
hraponte is offline
post #3 of 22 Old 10-27-2008, 02:53 PM
smalls23's Avatar
Send a message via AIM to smalls23
Originally Posted by hraponte View Post
sorry, but is this a trick question??? A 200/50/17 can only be 200mm wide.
the second digits (/50/)= profile or side wall height, but this number is a % of the width. In this case, the profile is 100mm.
Based on your question, i assume you don't know how to read the tire numbers, therefore the above explanation.
Take care.
smalls23 is offline
post #4 of 22 Old 10-27-2008, 03:06 PM
ZX-10R_Sinner's Avatar
There are variations in different manufacturer's though. That one tire review stated that a 190 BT016 was actually 193 wide, and some other manufacturer's 190's were slightly less than 190 at the widest point.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #5 of 22 Old 10-27-2008, 03:09 PM
smalls23's Avatar
yes, but do you think that any person will visually be able to tell, say a 200mm from a 203mm. No way. The numbers on the tires are going to be the main reference and little deviation should be present.
smalls23 is offline
post #6 of 22 Old 10-27-2008, 03:18 PM Thread Starter
Not a trick question. As stated above different manufactureres typically hav different variations in sizes. Just curious if anyone really knew?
SAkI is offline
post #7 of 22 Old 10-27-2008, 03:20 PM
I use 200/50 rear tires on 9 out of 11 of my bikes and my answer to the question is Bridgestones tend to be a little wider
ZX-10R (Black)
Skip114 is offline
post #8 of 22 Old 10-27-2008, 03:33 PM
zx10Duran's Avatar
I looked at them and dunlop has the widest 200 and maybe Michelin, my bridgestone 190 looks like a 180 compared to dunlop and michelin
zx10Duran is offline
post #9 of 22 Old 10-27-2008, 03:56 PM
I wondered this with my stock Dunlop, it looked wider than the Dragon Supercorsa and DCIII that I run now. What Bridgestone tire are you running that looks like a 180?
post #10 of 22 Old 10-27-2008, 05:15 PM Thread Starter
So, Dunlops or Mich?
SAkI is offline
Tire Warms Vs Tire socks Gang Green Performance and Tech 3 06-21-2008 11:02 AM
Tire Review: Dunlop N-Tec DOT rear race tire wsmc27 Track 4 08-09-2007 03:14 PM
tire psi - stock tire alteredZX-10 Strip 1 05-28-2007 08:06 PM
Would you feel safer on a Z(W) tire or a Z(Y) tire? Grease The ZX-10R 15 04-30-2007 01:10 PM
Monting rear tire without tire machine? blackisfaster Performance and Tech 9 04-24-2007 01:28 PM
