wideband? - Kawasaki ZX-10R.net
post #1 of 51 Old 09-02-2010, 09:50 PM Thread Starter
zx-sik-r's Avatar
wideband?
anybody running one?im gona order a wegoIII next week,my roomate just installed one on his 1000 last night so were gona see how well it works.super easy to wire up,just gota weld a bung into my sidewinder.
zx-sik-r is offline
post #2 of 51 Old 09-02-2010, 10:06 PM
Wego III is good stuff! Innovate logger is a great option as well.
Patrick is offline
post #3 of 51 Old 09-02-2010, 10:24 PM
i have run the innovates before and that is a bad ass system for sure. i just finished the turbo kit on my 06, and for peice of mind i wanted a wideband on it. right now i am not logging it, but i wanted the option next year when i have it on the track though. i am using all glowshift digital products on this build and i love them. the wideband was right around 200 and that comes with everything you need, the guage, the bosch sensore, the comp, all the harnesses and the harness to run to the data logger( if you have one all ready). but like i said, i am very impressed with these guages and for the price and the cleanliness of the kits i think they are deff worth lookin into
cj
general01 is offline
post #4 of 51 Old 09-03-2010, 03:13 PM
I have installed one on my Gen 3, I used the TPS ,the rpm signal and I have also conected the data recording ;-)
Uploaded with ImageShack.us
Zash is offline
post #5 of 51 Old 09-03-2010, 06:02 PM
Supercharged Mod
I have one; mine is just a plain ordinary AEM gauge, no logging no nothing. Still a useful thing to have.
So far, I've found that my bike is running unnecessarily rich at cruise, so there's fuel consumption and range to be found. Probably no power, though.
GoFaster is offline
post #6 of 51 Old 09-04-2010, 12:35 AM
JLAudio11's Avatar
I'm running a wideband commander and have been pretty happy with it. Big help for me at the track. It doesn't have the map suggestion feature like the wego does. It does have programmable outputs on it which will be running my nitrous. Once rpm, tp, and afr parameters are met she's sprayin, get off the gas, or hit the limiter and it's off, so sweet.
JLAudio11 is offline
post #7 of 51 Old 09-04-2010, 03:43 PM Thread Starter
zx-sik-r's Avatar
where did you guys pull a rpm signal from?
zx-sik-r is offline
post #8 of 51 Old 09-04-2010, 03:47 PM
Directly from the ignition coil ,I think I use the black/Green cable
Zash is offline
post #9 of 51 Old 09-04-2010, 10:05 PM Thread Starter
zx-sik-r's Avatar
i tried that and the signal is too noisy...straight off the coil....gona try and figure out wich one is coming off the ecu
zx-sik-r is offline
post #10 of 51 Old 09-04-2010, 10:22 PM
JLAudio11's Avatar
Yep mine is coming right off the ignition coil and no problems. Have you tried an injector yet if the coil wont work?
Wideband whith Lcd jcinfo Performance and Tech 3 06-18-2008 03:19 AM
Dyno Jet LCD and Wideband roland5color Vendor Deals 2 06-16-2008 04:17 PM
wtb wideband pc and o2 sensor hesaves0211 Wanted: Buy or Trade 9 06-11-2008 10:21 PM
Race ECu, PC3, Wideband, or others Dragone Performance and Tech 14 09-06-2007 12:35 PM
Wideband- bigbadninja Performance and Tech 6 07-09-2007 03:02 AM
