why use block off plates on 08zx10s???? - Kawasaki ZX-10R.net
post #1 of 9 Old 12-01-2010, 12:51 AM Thread Starter
trench's Avatar
seems to me that there is no good reason why as far as dyno tuning goes
trench is offline
post #2 of 9 Old 12-01-2010, 10:08 AM
Supercharged Mod
If you are using exhaust gas analysis, or even just a wide-band to measure air/fuel ratio, then the secondary air injection system needs to be blocked so that the exhaust gas measurement does not give a false lean reading. But, you don't need block-off plates to do that ... just plug the hose leading to the air suction valve.
GoFaster is offline
post #3 of 9 Old 12-01-2010, 10:58 AM
Speed Freak
garth285's Avatar
for sure when tuning this is a must. other wise you are letting fresh air enter the exhaust system when tuning, although supposedly when under full throttle the valve is closed but if your doing any sort of tuning on the bike its a must to have blocked off from the exhaust system
garth285 is offline
post #4 of 9 Old 12-01-2010, 01:30 PM Thread Starter
trench's Avatar
yes that i understand but if u look at the 08 system, there is no air being injected into the exhaust. vapors r pulled from the valve cover into the airbox only
trench is offline
post #5 of 9 Old 12-01-2010, 01:37 PM
Speed Freak
garth285's Avatar
Not correct, the vapors are not coming from under the valve cover, those go directly to small port holes that are actually connect directly to the exhaust ports.
garth285 is offline
post #6 of 9 Old 12-01-2010, 05:42 PM Thread Starter
trench's Avatar
ok thnks garth. so would placing something into the hose coming from the air box do the same thing as block off plates?
trench is offline
post #7 of 9 Old 12-01-2010, 05:44 PM
Speed Freak
garth285's Avatar
you can take a piece of hose and connect both of the outlets of the valve cover together and then then block off the hole that goes into the air box
garth285 is offline
post #8 of 9 Old 12-01-2010, 05:50 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
TMY10ER is offline
post #9 of 9 Old 12-07-2010, 09:34 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
Got my plates done,still pops a lil..O well it will help when i get a few more mods on it and dyno mapped..
craig_sez is offline
block off plates zx10-06 Performance and Tech 6 01-04-2010 01:24 AM
Block Off Plates ninjasuz Performance and Tech 15 02-21-2008 11:35 AM
Block off plates?? vjhils Performance and Tech 6 12-10-2007 09:29 AM
Block-off plates??? 1bad10r Performance and Tech 12 01-06-2007 08:58 PM
Block off plates Floyd Vendor Deals 6 06-10-2005 05:30 PM
