why are slip-on maps for PCIII full of negative numbers? - Kawasaki ZX-10R.net
post #1 of 9 Old 07-21-2007, 08:26 AM Thread Starter
Here is an example of numbers from a map for a two-brothers slipon from the power commander site. I thought to get more fuel the % change had to be a positive number...does this mean that this map will actually reduce the amount of fuel where the numbers are negative? WTF???????
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 3 0 0 0 0 0 0 0
0 0 -5 0 -9 -13 -12 -15 -10
0 -2 -5 -4 -4 -7 -9 -9 -6
0 2 -5 -3 -9 -15 -15 -17 -15
0 -4 -3 -9 -15 -20 -19 -22 -20
0 3 3 -7 -2 3 2 1 -2
0 5 7 10 13 7 6 6 12
0 0 1 7 20 10 9 10 14
0 -9 -3 5 13 -2 -5 -3 4
0 0 -8 -9 -2 -14 -18 -18 -11
0 0 -6 -12 -5 -10 -14 -16 -10
0 0 -1 -4 -5 -7 -10 -10 -7
0 0 0 -3 0 -2 -5 -5 -3
0 0 1 1 -2 2 -3 -2 -6
0 0 -3 -1 1 3 2 2 -1
0 0 -5 -5 -3 2 -3 -1 -1
0 0 -4 -1 0 5 0 2 0
0 0 0 5 5 -1 -6 -3 -4
0 0 0 11 13 -3 -7 -3 -3
0 0 0 9 11 1 -2 2 0
0 0 0 8 10 2 -5 2 1
0 0 0 9 12 4 -1 0 1
0 0 0 8 11 5 0 1 0
0 0 0 8 8 6 0 3 3
0 0 0 11 5 4 -1 4 3
0 0 0 7 7 6 4 5 5
0 0 0 9 7 7 5 8 7
0 0 0 10 4 4 5 8 8
0 0 0 10 5 5 5 10 10
0 0 0 5 2 5 6 7 7
0 0 0 2 3 7 5 6 8
0 0 0 -1 5 4 2 5 4
0 0 0 2 3 2 1 3 3
0 0 0 -2 3 6 3 5 3
0 0 0 -4 2 4 3 2 1
0 0 0 0 0 3 4 5 2
0 0 0 0 -2 1 2 2 0
0 0 0 0 -5 0 5 5 2
0 0 0 0 -8 -3 3 4 2
0 0 0 0 -10 -6 1 2 0
0 0 0 0 -12 -9 0 4 0
0 0 0 0 -15 -8 -1 2 0
0 0 0 0 -16 -10 -3 1 0
0 0 0 0 -14 -12 -5 2 1
0 0 0 0 -16 -16 -7 1 1
0 0 0 0 -12 -12 -5 1 2
Bikes ever owned:
2004 Kawasaki zx12r
1994 Kawasaki zx7r
2004 kawasaki zx10r
2001 kawasaki zx9r
1989 kawasaki zx10
1996 suzuki gsxr 750
1998 honda vtr1000
1994 kawasaki zx6e
1985 yamaha fz750
1984 honda nighhawk 750s
1988 yamaha fz600
cdnzx10r is offline
post #2 of 9 Old 07-21-2007, 08:52 AM
FuTAnT's Avatar
Images: 7
You've based your query on one very large assumption (I assume .. ha .. maybe I am wrong too!). And that is, that the factory map is correct.
Now, we know that is not so. Take a look at the stock Euro map for example, it's full of -ve number indicating that in certain ranges the bike is running too rich.
Translate this to a pipe, and yeah, you may still have to lean it out rather than richen it up. Just because you put a pipe on and let a bit more flow through does not always translate to more fuel being required to be injected.
Some of the late 90s Fireblades actually went *down* a jet size or two when you put pipes on them.
I guess what I'm trying to say is that just because you put a pipe on, does not mean you always need to richen the map up all the way through.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
'85 GSX250S -> '96 ZX6R -> '98 ZX6R -> '00 ZX6R -> '03 CBR954RR -> '04 ZX10R -> '02 ZZR250 -> '06 ZX10R -> '08 KTM 990 ADV
FuTAnT is offline
post #3 of 9 Old 07-21-2007, 09:13 AM
black 10r's Avatar
I just installed my PCIIIUSB on my 06 10r with a sato slip on. I had the shop preload it with that same map that cdnzx10r speaks of to give me some sort of baseline map. Prior to the PC with just the pipe throttle response lagged and in the mid range it acted as if it was loading up (to rich). Well I can tell that the throttle response is much better and mid range power is instantaneous. The popping on deceleration has been reduced. One thing that does concern me is the presence of the flashing FI warning light. Is this normal. Is there something that can be done about this whether with the PC or simply unplugging it. Hopefully someone can give me some advice.
black 10r is offline
post #4 of 9 Old 07-21-2007, 09:27 AM Thread Starter
I hear ya- and I thought about the same thing...Its just that I was under the impression that the stock map is pretty lean to allow for passing emission/noise test, etc especially in the low RPM range and I thought this is where the PCIII would richen up the mixture...So I was rather shocked to see that at some points, it is actually making it leaner by as much as 20%...
Bikes ever owned:
2004 Kawasaki zx12r
1994 Kawasaki zx7r
2004 kawasaki zx10r
2001 kawasaki zx9r
1989 kawasaki zx10
1998 honda vtr1000
1994 kawasaki zx6e
1985 yamaha fz750
1988 yamaha fz600
cdnzx10r is offline
post #5 of 9 Old 07-21-2007, 09:50 AM
La Flama Blanca
9R to 10R's Avatar
Images: 102
If you removed the servo that used to move your exhaust flapper valve when you installed your slip on, thats what is causing your FI light. Put the servo back in and hook it up with out the cables and the light will go away.
9R to 10R is offline
post #6 of 9 Old 07-21-2007, 07:22 PM
black 10r's Avatar
Thanks for your post 9r to 10r. It made me think about the position of the servo when I took the cables off. I turned the servo to the neutral position about a 1/4 inch clockwise and all is well, no FI error light. Thanks again.
post #7 of 9 Old 07-21-2007, 08:46 PM
abadassbikerlad's Avatar
Send a message via MSN to abadassbikerlad
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 3 0 0 0 0 0 0 0
0 0 -4 -1 0 5 0 2 0
0 0 0 9 11 1 -2 2 0
0 0 0 8 10 2 -5 2 1
0 0 0 9 12 4 -1 0 1
0 0 0 8 11 5 0 1 0
0 0 0 8 8 6 0 3 3
0 0 0 11 5 4 -1 4 3
0 0 0 7 7 6 4 5 5
0 0 0 9 7 7 5 8 7
0 0 0 10 4 4 5 8 8
0 0 0 5 2 5 6 7 7
0 0 0 2 3 7 5 6 8
0 0 0 -1 5 4 2 5 4
0 0 0 2 3 2 1 3 3
0 0 0 -2 3 6 3 5 3
0 0 0 -4 2 4 3 2 1
0 0 0 0 0 3 4 5 2
0 0 0 0 -2 1 2 2 0
0 0 0 0 -5 0 5 5 2
0 0 0 0 -8 -3 3 4 2
that could be what i am seeing look at my post ....https://www.zx-10r.net/forum/showthread.php?t=42476
2013 black uk spec gen 4, full akrapovic evo carbon, brembo rcs master cylinder, brembo clutch, ohlins race SCU, woolichracing flashed ecu with stock 02 disabled, ohlins mechatronic rear shock, Suoer corsa Sc2 200 rear smoked hot bodies rear end, Puig screen, s-2 concepts seat hump,Hell hoses, brembo m4 monoblocks samco sport red hoses, samco clamps, evotech oil cap, MWR filter, Putoline syntec 4, Jmt lion battery, nearly all bolts are titanium. 55w 6000k 2.5" Hid projectors.
190.26 hp Din
abadassbikerlad is offline
post #8 of 9 Old 07-22-2007, 04:40 PM Thread Starter
Yeah, I actually followed your thread already...Here's my question: did you just randomly type in 23% or whatever by yourself to see if it makes a difference? or did you do it based on some specific information?
thanks
Bikes ever owned:
2004 Kawasaki zx12r
1994 Kawasaki zx7r
2004 kawasaki zx10r
2001 kawasaki zx9r
1989 kawasaki zx10
1998 honda vtr1000
1994 kawasaki zx6e
1985 yamaha fz750
1988 yamaha fz600
cdnzx10r is offline
post #9 of 9 Old 07-26-2007, 03:03 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
B4 i had my bike on the dynajet dyno,my 06 10r ran way rich..I have the 2bro slip on(crap)a bmc race a/f and of corse a pc3usb...After i got it mapped it was maken another 8 hp..
I would rather rich than lean..lol
craig_sez is offline
PCIII/TRE/Ignition Module/Ivan's Maps wattgn Performance and Tech 14 01-09-2007 11:03 AM
PCIII usb losing maps mrzw70 Performance and Tech 2 08-15-2005 03:23 PM
Are Ivan's PCIII maps any good? DB's ZX10R Performance and Tech 8 07-03-2005 10:05 PM
what does the numbers in maps mean? green04zx10r Performance and Tech 17 06-07-2005 02:43 PM
PC3 maps for Akrap Slip ons ? Finatic-1 The ZX-10R 2 06-04-2004 07:48 PM
