Who's using the accelerator pump on PCIII - Kawasaki ZX-10R.net
post #1 of 5 Old 05-03-2006, 05:33 PM Thread Starter
hello, all new to the site and wondering if anyone is using the accelerator pump option on the pciii and what is it set at I'd like to try out, I've got an 05 zx10 brock full system, brock map, bmc race filter,dano derestricter, does it really help?
phatkid is offline
post #2 of 5 Old 05-03-2006, 08:00 PM
tank zx10r's Avatar
Images: 52
just did it today and it is unreal went out to test it and 1st ,2nd iam used to it coming up but not third gear it came up like i popped the clutch and I was shifting faster with my air shifter it worked for me but im going to still play with the settings
tank zx10r is offline
post #3 of 5 Old 05-03-2006, 08:05 PM
How's the derestrictor working out for ya..?
2011 Black Pearl WRX - Accessport tuned...
2009 Burnt Orage 10R - Jardine GP, K&N Race, Dynotronics flash, Q2s.
2005 Matte Black 10R - Akra slip, PC, K&N, 37K miles, SOLD, MISSED.
1998 RM250 - Yellow....!
GRKZX10R is offline
post #4 of 5 Old 05-04-2006, 05:50 AM
Supercharged Mod
An "accelerator pump" function should not be required on a fuel-injected engine. PERIOD. There is no reason for it. The ECU recalculates the correct injection quantity on every revolution of the engine. Where is the lag that an "accelerator pump" supposedly compensates for? (Answer: there isn't one.)
If playing with the accelerator pump feature has any sort of positive result, your map is not correct.
GoFaster is offline
post #5 of 5 Old 05-04-2006, 06:28 AM
Just a way to compensate for a crappy map, IMO. Like GoFaster said, a properly mapped FI system doesn't need an accelerator pump. Carburetors do.
CanyonCarver is offline
Effectiveness of an aftermarket exhaust and/or PCIII MAVRIK The ZX-10R 10 07-09-2010 02:31 PM
Let the the truth be told PCIII usb GREENDEL Performance and Tech 114 05-31-2007 10:41 AM
04/05 ZX10R PCIII owners... sneaky Performance and Tech 4 04-21-2006 07:52 AM
full system w/o pcIII jeff Performance and Tech 12 02-18-2005 08:47 AM
Reprogramming ECU instead of getting PCIII USB? RichTJ99 The ZX-10R 17 10-18-2004 05:16 PM
