Where to get brake shimmy/heat things - Kawasaki ZX-10R.net
post #1 of 12 Old 07-12-2005, 06:52 PM Thread Starter
So a couple of weeks ago I decided to replace my pads with some galfer HH pads before a Jennings GP track day. I told my mechanic to not put the backing plate from my OEM pads on my new ones. I now have a vibration on initial brake input and it goes away with more firm pressure. It started before my track day and trip to deals gap so I don't think I warped the rotors at a track day. I seem to think that those plates on the back of the pads must preload them against the rotor a bit. Now I never saw the actual plates that we have all spoken about so If anyone has a pic of them I would appriciate it. Also I don't see them on the parts diagram on kawa.com. Where can I get them? The only other service I had done at the same time was have the front tire replaced
tigerflyboy is offline
post #2 of 12 Old 07-12-2005, 06:57 PM
busaforhire's Avatar
wonder if they bent the rotor a hair when replacing the front tire?
busaforhire is offline
post #3 of 12 Old 07-12-2005, 06:59 PM
The ss backs are to disperse heat, the galfer pads are ceramic backed, you shouldn't need them.
ELRWFO is offline
post #4 of 12 Old 07-12-2005, 07:13 PM
grover's Avatar
Send a message via AIM to grover
I had the same thing happen to me but it was the rotor. The guy that changed my tires had sprayed bead lock crap on my front rotors. When i hit the brakes it glazed my pads. I had to bead blast the rotor and replace the pads. I tried sanding them but it didn't work.
grover is offline
post #5 of 12 Old 07-13-2005, 12:29 AM
When you buy the oem pads they come with new shims. Why, exactly, did you switch from the oem pads? What about them was unsatisfactory?
mad kaw is offline
post #6 of 12 Old 07-13-2005, 03:39 AM
crispin's Avatar
Send a message via AIM to crispin
I changed mine as I felt the brake lever hitting the grip after a few laps was a bit unsafe.
The stock pads fade bad under strong use.
crispin is offline
post #7 of 12 Old 07-13-2005, 08:25 AM
I Have Only Hear The Stock Pads Doing That On The Track....which Is Understandable...
MAVRIK is offline
post #8 of 12 Old 07-13-2005, 08:27 AM
lmao..unsafe huh...
post #9 of 12 Old 08-19-2005, 12:10 PM
What about the little clip that goes above the pads does that need to be put back or is it unimportant?
Nasty10R is offline
post #10 of 12 Old 08-19-2005, 01:00 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
Exclamation
Im just guessing here...but if it helps to hold you brakes together, Id put it back on there...
hillcountry10r is offline
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 06:58 PM
rear hydraulic brake switch for the 10R-$15 shipped steves87 Parts, Gear and Accessories 6 05-20-2005 06:04 PM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 04:27 PM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 01:29 PM
Member Special: Galfer SS Brake Lines & HH Pads Cal-Sportbike Vendor Deals 8 08-01-2004 12:11 AM
