Wheel Bearing Removal Tip - Kawasaki ZX-10R.net
post #1 of 8 Old 03-07-2008, 04:18 PM Thread Starter
JOSHUAZX10's Avatar
Images: 7
Send a message via Yahoo to JOSHUAZX10
Hey guys and gals, if anyone out there is going to remove their wheel bearings I have a tip for ya. This is for anyone that doesn't have special tools and doesn't want to purchase them. Autozone rents a blind hole puller (part #27128) and a bearing driver set (part # 27119) that work really well. Just pay $140 deposit on the puller set and $50 deposit on the driver set and you will get your money back when returned. Worked great for me, hope it helps some of you too...
JOSHUAZX10 is offline
post #2 of 8 Old 03-07-2008, 04:43 PM
zx10Duran's Avatar
Good Idea, I was thinking about pulling mine this month before spring hits I got 22k on them already
zx10Duran is offline
post #3 of 8 Old 03-07-2008, 04:48 PM Thread Starter
JOSHUAZX10's Avatar
Images: 7
I don't have a ton of miles on mine, just had to take them out to get the wheels powdercoated...either way it works very well and you can't beat it for free
post #4 of 8 Old 03-08-2008, 09:35 AM
Josh> How do you rent a tool for free?
I bought a Wheel Bearing Puller from Pitposse Tools for $42 and it was money well spent.
Johnnyboy is offline
post #5 of 8 Old 03-08-2008, 09:57 AM Thread Starter
JOSHUAZX10's Avatar
Images: 7
Umm, like I said you put a deposit down and you get a full refund when you return it. Which is what makes it free...
post #6 of 8 Old 03-09-2008, 02:33 PM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
How long did it take you, was it hard? Did you buy new bearings. I am about to get my Wheels Powder Coated and am wondering these things.
Thanks
OneSLOW10 is offline
post #7 of 8 Old 03-09-2008, 02:41 PM Thread Starter
JOSHUAZX10's Avatar
Images: 7
Thanks
I'd say taking the wheels off of the bike is the most time consuming. Before you can use the tool I mentioned in my first post you'll have to use the punch or extension with a hammer to get one of the bearings out like 1/4". After that the tool makes it very easy. And no, as long as you don't mess up the rubber seals they should be fine to put back in...unless you have a lot of miles on them then it is best just to replace them while they're already out
post #8 of 8 Old 03-09-2008, 04:18 PM
OneSLOW10's Avatar
cool - thanks. I have a little over 1k on mine so i should be good then. Thanks again
wheel bearing JeredH Performance and Tech 12 11-10-2007 11:54 AM
Rear Wheel Bearing destroyed?? Help ICE-MHR Performance and Tech 10 07-18-2007 02:37 AM
04 Forks, 06 wheel: bearing swap not possible? Vonstallin Performance and Tech 4 06-29-2007 05:09 PM
04 front wheel bearing and seals hesaves0211 Vendor Deals 6 06-22-2007 02:15 PM
wheel bearing removal 10roller The ZX-10R 9 05-09-2006 05:00 AM
