wheel bearing - Kawasaki ZX-10R.net
post #1 of 13 Old 11-09-2007, 10:33 AM Thread Starter
JeredH's Avatar
Send a message via MSN to JeredH
wheel bearing
I've been reading a lot of threads about the wheel bearings, and am going to order a set for my 2004 ZX10.
I also need bearings for 2005 ZX-6RR. Anyone know if the bearings are the same for these wheels?
I have this info for the bearings on thte 10R
2 NSK6004vv
2 NSK 6204vv
1 NSK 6205vv
(will order from bearingworks.com)
Thanks all!
JeredH is offline
post #2 of 13 Old 11-09-2007, 11:39 AM
Big Daddy's Avatar
Images: 38
Check the KHI OEM part #'s for both bikes is 1 way but since they must be removed ya might as well wait and get the #"s off the bearings themselves.
Big Daddy is offline
post #3 of 13 Old 11-09-2007, 12:35 PM Thread Starter
JeredH's Avatar
10-4.
I have two sets of wheels for both bikes. the bearings on the ZX-6 are fine, but from what you said BD about how easy these bearings spin, i would like to upgrade all bearings from factory to the ones offered by bearingworks. and i would rather not yank the good ones until i need to.
i will do further research.
JeredH is offline
post #4 of 13 Old 11-09-2007, 07:22 PM
lunitk's Avatar
What was your total price for just the 10R bearings....I have been thinking about this mod myself for a while.
lunitk is offline
post #5 of 13 Old 11-09-2007, 07:33 PM
Big Daddy's Avatar
Images: 38
They have gone up cost wise since i did mine 3yrs ago but i suspect about $80 for 1 set.
post #6 of 13 Old 11-09-2007, 10:26 PM
bkkninja's Avatar
What about low friction bearings? are they available for ZX10R?
bkkninja is offline
post #7 of 13 Old 11-09-2007, 11:08 PM
Speed Freak
garth285's Avatar
they have ceramic bearings but the set is about 400 bux.... i have them in my rims and tranny. makes everything spin a lot better.
garth285 is offline
post #8 of 13 Old 11-09-2007, 11:14 PM
bkkninja's Avatar
Is it noticable and worth the expense?
bkkninja is offline
post #9 of 13 Old 11-10-2007, 01:00 AM Thread Starter
JeredH's Avatar
concensus says that the difference b/t ceramic and a good steel bearing is marginal. whereas the cost is about 400% greater for ceramic.
the pitfalls of ceramic bearings are that they are more "fragile" than steel bearings. most say not to use ceramic for the street due to road conditions posing a hazard to the ceramic bearings. the street is just too rough to justify spending four times as much for a something that is, say, four times likely to break.
JeredH is offline
post #10 of 13 Old 11-10-2007, 03:26 AM
10R Joe's Avatar
Images: 9
With 60k kms on the clock on my ride, this is something i plan on doing this winter also.
10R Joe is offline
Rear Wheel Bearing destroyed?? Help ICE-MHR Performance and Tech 10 07-18-2007 02:37 AM
04 Forks, 06 wheel: bearing swap not possible? Vonstallin Performance and Tech 4 06-29-2007 05:09 PM
04 front wheel bearing and seals hesaves0211 Vendor Deals 6 06-22-2007 02:15 PM
wheel bearing removal 10roller The ZX-10R 9 05-09-2006 05:00 AM
Wheel Bearing and Axle Torque Question Gunner Performance and Tech 13 03-29-2006 12:31 PM
