whatelse should i do ? - Kawasaki ZX-10R.net
post #1 of 17 Old 08-31-2010, 05:25 PM Thread Starter
BAYBOI's Avatar
Ok im going be replacing my cams,doing a valve adjustment ,changing spark plugs,new valve cover gasket and thinner head gasket whatelse should i do ?
am i missing anything maintenance wise my has 23k on it 05 zx10
BAYBOI is offline
post #2 of 17 Old 08-31-2010, 05:32 PM
formerly GHOST RIDER
SOUN1's Avatar
Oil , coolant , brake fluid....I have the same bike with higher mileage, I may brake down and give her a make over too..
SOUN1 is offline
post #3 of 17 Old 08-31-2010, 06:51 PM
Quick10's Avatar
valve spring retainers
Quick10 is offline
post #4 of 17 Old 09-07-2010, 01:44 PM Thread Starter
BAYBOI's Avatar
you havent done a valve adjustment yet ? mines isnt making any noise but sense im going to swap cams might as well have the valves adjusted also
BAYBOI is offline
post #5 of 17 Old 09-07-2010, 01:45 PM Thread Starter
BAYBOI's Avatar
what do those do ?
BAYBOI is offline
post #6 of 17 Old 09-07-2010, 01:51 PM
DGA
DGA's Avatar
They retain the valve springs from flying out of the engine.
If you are going as far as replacing the cams (are you going with the stock ones?) with the aftermarket ones, with more aggressive lift and duration, it would be smart to replace the valve springs with beefier units, if it's called upon.
DGA is offline
post #7 of 17 Old 09-07-2010, 01:54 PM Thread Starter
BAYBOI's Avatar
yes im going with kawi race cams ok thanks i needed that info thanks alot i just wrote it on the to do list
BAYBOI is offline
post #8 of 17 Old 09-07-2010, 05:07 PM
SOUN1's Avatar
No, no valve job yet..Sh*t, I still have the stock spark plugs , clutch, chain & sprocket
SOUN1 is offline
post #9 of 17 Old 09-07-2010, 05:35 PM Thread Starter
BAYBOI's Avatar
lol you crazy man i have -1 +1 with new chain did my exhaust filter pc3 and i do my oil changes on time and thats it i want this thing running better then new im going to change the plugs while everything is apart might as well
BAYBOI is offline
post #10 of 17 Old 09-07-2010, 05:35 PM
zx racer's Avatar
i would replace the oem cam chain tensioner for a APE manual adjuster. cheap insurance & it will help keep that motor runnin quiet :)
zx racer is offline
