what size is the steering stem nut - Kawasaki ZX-10R.net
post #1 of 5 Old 06-09-2007, 12:05 AM Thread Starter
Hi,
I am trying to install the GPR damper and I need to remove the steering stem nut. Can some of you tell me what size the nut is? I measured it to be 35mm but I just want to make sure. Also, where do you get a 35mm socket? Are those like $10 or more a piece?
Thanks,
Jack
rocktboy is offline
post #2 of 5 Old 06-09-2007, 12:24 AM
36mm and napa would probably have them. It's a common size used for axle nuts.
kawazeppelin is offline
post #3 of 5 Old 06-09-2007, 12:30 AM Thread Starter
thanks!
rocktboy is offline
post #4 of 5 Old 06-09-2007, 08:33 AM
corners's Avatar
Get a 12pt one. I got a 6pt when I took the nut off, and when I went to put it back on the 6pt is just a hair thicker it wouldn't fit in the GPR bracket. I went to Sears and got a 12pt for $9
Don't be afraid that your life will end,
be afraid that it will never begin.
~anonymous~
corners is offline
post #5 of 5 Old 06-09-2007, 08:53 AM
hangman39's Avatar
got a whole set of large metric sockets for $20 at Harbor Freight
hangman39 is offline
steering stem lock rings; how big??? latdrop The ZX-10R 5 09-09-2010 03:44 PM
zx stem size draven Welcome Newbies! 5 01-14-2006 08:59 PM
steering stem bearings and kawa CDI tuning Riceburner The ZX-10R 10 06-12-2005 12:40 AM
Torque spec 4 steering stem nut? HPower Performance and Tech 19 11-16-2004 08:28 AM
really quick guys, what size is the stearing stem nut? FrEteGi The ZX-10R 16 08-05-2004 02:26 PM
