what says F1? (KAwa zx10r 2004) - Kawasaki ZX-10R.net
post #1 of 8 Old 06-02-2013, 01:41 PM Thread Starter
Post what says F1? (KAwa zx10r 2004)
Hi all,
When my engine isnt running , my F1 indicator does flashing all the time....is that Oke'?
When its running.....F1 is burning all the time......dont know if its burning all the time when the engine is on temprature....because i have the Kawa for just a month...and its only for circuit .....its agains the law to drive this on the road.(no title)
Thanks for reply and support.
Eddy
KAWAeddy is offline
post #2 of 8 Old 06-02-2013, 04:32 PM
zx racer's Avatar
you will need to pull the codes to see why the FI light is on... its lil plug underneath the driver seat you can jump to see wat code is popin up.
05 ZX-10R SWB.
zx racer is offline
post #3 of 8 Old 06-03-2013, 01:40 PM Thread Starter
Thanks for reply ZX Racer,
Which one do you mean?
Ed
KAWAeddy is offline
post #4 of 8 Old 06-03-2013, 02:05 PM
Slow Poke
bgmagma10's Avatar
Should be a connector connected to the end of this orange wire. This is the dealer mode wire which is what your need to ground out to get your code
bgmagma10 is offline
post #5 of 8 Old 06-03-2013, 04:10 PM
Does not drive into smoke
El Zilcho's Avatar
There is a wire there that has a vinyl tube at the end. You need to stick another wire in there and route it to the ground (like the frame). Then turn the ignition key and the FI light should emit a series of flashes: long and short. Count the long ones, then count the short ones, together you'll get a 2-digit number. That's the code.
El Zilcho is offline
post #6 of 8 Old 06-03-2013, 04:39 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
Here's a write up on how to and the codes.
https://www.zx-10r.net/forum/showthread.php?t=122201
hellsrazor is offline
post #7 of 8 Old 06-04-2013, 12:10 PM Thread Starter
Thanks guys , i will check this out!
Nice work Hellsrazor,
Eddy
KAWAeddy is offline
post #8 of 8 Old 06-09-2013, 12:52 PM
hellsrazor's Avatar
Images: 23
Did you ever figure it out ???
Update us
zx10r 2006 frame on zx10r 2004/2005 hookzx10r The ZX-10R 9 02-10-2009 03:48 AM
Kawa must race JCollins Race and Stunt 4 01-14-2009 09:19 PM
[Race]Corvette 703hp Vs 170hp Kawa ZX10R hesaves0211 Pictures and Videos 26 06-26-2007 12:59 PM
Original Kawa ZX10R Race brake line kit installed lespaul66 Performance and Tech 12 07-21-2005 08:07 PM
