What?!? Is it just me... - Kawasaki ZX-10R.net
post #1 of 30 Old 08-15-2006, 12:38 PM Thread Starter
Rock_Star's Avatar
All,
Took my rear rim off for first time ( on the 10R that is) and there was absolutly zero lube or grease on the rear axel. The rim has never been off the bike...
All of my 8 previous bikes Ive taken apart have always has lube/grease on both axels.
Is this just my 10R or what???
BTW - my 10R has been garaged its whole life...
Rock_Star is offline
post #2 of 30 Old 08-15-2006, 12:44 PM
byebyebusa's Avatar
Images: 7
Send a message via AIM to byebyebusa Send a message via Yahoo to byebyebusa
Grease = weight lol
I noticed the same thing on my 10 and the new 14, they don't slap grease on everything like the Zukes do.
byebyebusa is offline
post #3 of 30 Old 08-15-2006, 12:51 PM
Supercharged Mod
Suggestion: Take the swingarm pivot bolt out, and grease that up and re-install it.
If you don't, you might eventually end up with a situation like I have on another older bike: non-removable swingarm because the pivot bolt is seized in the bushing inside. I'm hoping those bearings never go bad ...
GoFaster is offline
post #4 of 30 Old 08-15-2006, 01:03 PM Thread Starter
Rock_Star's Avatar
I cant believe Kawa doesnt grease any of thier Sh*t!
I guess I will be using the lube tonight!! haha
post #5 of 30 Old 08-15-2006, 01:34 PM
Try using the " Search " botton
bkbroiler is offline
post #6 of 30 Old 08-15-2006, 01:40 PM Thread Starter
Rock_Star's Avatar
hey bk,
I searched lube, grease, axel and only found...
https://zx-10r.net/forum/showthread.php?t=23367
which diddnt say much.
Why dont you get back to flippin burgers???..
Are you still mad about the exhuast???
post #7 of 30 Old 08-15-2006, 03:52 PM
Post Whore
1killer1liter's Avatar
Images: 11
You should have spelled AXLE correctly and you would have come up with more results.
1killer1liter is offline
post #8 of 30 Old 08-15-2006, 03:52 PM
rocketracermike's Avatar
Originally Posted by Rock_Star
hey bk,
Thats normal. very little grease. if you look at the rear hub through those large hole. you will see the axle is expose . less grease is less dirt on the axle. this way. when you pulled the axle out. you won't pull dirt into the bearings.
rocketracermike is offline
post #9 of 30 Old 08-15-2006, 04:04 PM Thread Starter
Rock_Star's Avatar
I spelled correctly on the search and only found...
which still did not answer my question.
Its not like Im asking, "which exhaust should I get..." or "how do I change my oil"
post #10 of 30 Old 08-15-2006, 04:06 PM Thread Starter
Rock_Star's Avatar
Less grease = less grit... makes sense
I guess I was expecting more, like on my other bikes... thanks
