What is a Full Service - Kawasaki ZX-10R.net
post #1 of 11 Old 03-25-2011, 07:28 AM Thread Starter
ikaika's Avatar
Curious, my 08 ZX10R has 21000 miles and I was going to make an appointment with the dealer for a full service. The bike runs great. I change the oil every 3000 miles with Motul 300V and always ensure the pads, chain, and sprockets are good. They quoted me $200.00. Anyone know what do the mechanics do for the service? Wanted to know if it was worth it to take it in. Thanks for the help.
ikaika is offline
post #2 of 11 Old 03-25-2011, 10:55 AM
blink.'s Avatar
They wouldn't tell you what there "full service" is? Anyway by the sounds of it, you seem to know what the wear and tear items are and how to replace, so no I wouldn't waste the money...
blink. is offline
post #3 of 11 Old 03-25-2011, 11:14 AM
davbib's Avatar
Sounds like a nice way of saying "We plan on screwing you real good by making it seem like we did a ton of work when we really only changed the oil. At most check valve clearances."
I'd ask that to be itemized.
davbib is offline
post #4 of 11 Old 03-25-2011, 11:16 AM
Starbucks Connoisseur
Static IP's Avatar
If you go to a dealship then a full service is a Con Job lol.
It should all be in your manual. It's usually around $450-$550 and if you haven't done at all till 21k, you are way past due.
It's oil, plugs, checkand adjust valves, timing, coolant, rear & front brake oils, check cables, etc. Your bike might be riding great, but certian things just taper off slowly and subltly that you just won't notice till you get it done and get the bike back and you're like WHOA!
Static IP is offline
post #5 of 11 Old 03-25-2011, 11:46 AM
blink.'s Avatar
I don't know many dealerships that will actually do a valve job for the full service price, most I seen they will check them, tell you need a valve job, then hit you with hourly charge to go swapping out shims..
blink. is offline
post #6 of 11 Old 03-25-2011, 11:58 AM
Static IP's Avatar
DO NOT GO TO A DEALERSHIP! EVER!!
(unless your uncle owns it)
I had posted a VERY detailed reason as to why you should NOT go to a dealership and %99 on this board will agree. You can check out a thread on my experience:
https://zx-10r.net/forum/showthread.p...ica+kawa saki
post #7 of 11 Old 03-25-2011, 05:30 PM Thread Starter
ikaika's Avatar
Thanks for all the advice. It is greatly appreciated.
ikaika is offline
post #8 of 11 Old 03-25-2011, 08:26 PM
lil ninja's Avatar
Send a message via MSN to lil ninja
the posts above have covered alot of what should be checked at that mileage but they should also check brake rotor thickness and clutch fiber and steels thickness.
lil ninja is offline
post #9 of 11 Old 03-26-2011, 04:44 AM
Static IP's Avatar
Oh and last but not least, make sure the is a Starbucks with in walking distance, this of course should go without say :)
post #10 of 11 Old 03-26-2011, 06:28 AM
Dont mess wit White Ninja
abzx10r's Avatar
I do everything on my bike but every 10k I suck it up and take it in. Full service on my end is 470ish and they do everything. Great little shop, family owned and the guy used to race with my father!
abzx10r is offline
2005 ZX-10R, Full Service History HugeRacing Bikes 4 Sale 3 07-29-2009 01:15 AM
Slip-on, full, full w/ power commander, bazzaz ? What do you have? GosuPaintballer The ZX-10R 37 02-28-2009 06:28 PM
Need Full Time Service Tech In Nc!!! GETNASTY Wanted: Buy or Trade 1 12-21-2006 07:05 PM
