What the F#$* - Kawasaki ZX-10R.net
post #1 of 16 Old 01-03-2005, 09:18 AM Thread Starter
Angry What the F#$*
I'm trying to take the battery out, what a complete pain in the ass. I have had 7 sportbikes before my beloved 10. However, this is the worst design I've seen so far to remove the battery. And yes all the lines are removed, it is just very hard to grab ahold of ANY part of the battery to pull it out. Any suggestions?
joecop30 is offline
post #2 of 16 Old 01-03-2005, 10:05 AM
1rocket69's Avatar
Location: Used to be Candler, NC/ Then HELL in Del Rio, Tx/ Now Blaine, WA
battery removal
I have not tried it yet but this has been discussed here before, doesn't sound like there is a easy way. maybe this will help.https://www.zx-10r.net/forum/showthread.php?t=4355
1rocket69 is offline
post #3 of 16 Old 01-03-2005, 11:29 AM Thread Starter
Thanks 1Rocket...it is a complete pain in the ass...me thinks I will throw the battery tender on it.
joecop30 is offline
post #4 of 16 Old 01-03-2005, 12:04 PM
Post Whore
Older Guy's Avatar
Pick bike up...turn upside down...shake vigoriously...battery should drop out...spray some WD-40 round it first...
Older Guy is offline
post #5 of 16 Old 01-03-2005, 12:56 PM
MIA Post Whore
miykl's Avatar
if shaking doesn't work, tap with a rubber mallet under the tray while holding the bike inverted.
miykl is offline
post #6 of 16 Old 01-03-2005, 02:21 PM
crispin's Avatar
Send a message via AIM to crispin
Or let me try to Wheelie it for you.
I think I can knock the battery right out and possibly the motor as well if you wish.
I will need to aquire a football suit first as motorcycle gear is just not padded enough for me.
Have you all seen those Sumo Wresling outfits that make you look like you weight 500 lbs,
that would be perfect!
ya ya ya...
crispin is offline
post #7 of 16 Old 01-03-2005, 02:24 PM
OG Post Whore
stunnerific_harry's Avatar
Send a message via AIM to stunnerific_harry
ghost ride it into a guard rail, battery should come flying out
stunnerific_harry is offline
post #8 of 16 Old 01-03-2005, 06:03 PM
get some plastic hook & loop (like velcro but WAY strong) at Radio Shack. stick a few pieces to the top.
Mal
'12 ZX-14R
'12 ZX-10R
65+ and medicated
zx9rmal is offline
post #9 of 16 Old 01-03-2005, 06:43 PM
crispin's Avatar
that is probely the only real help on this thread.
ya ya ya...
crispin is offline
post #10 of 16 Old 01-03-2005, 07:06 PM
Relax and SMOKE and the answer will come to you!!! Wait until you have to take the airbox completely out of the bike... Tight inside the frame.. I took a file and removed alot of material before reinstalling it.. And yes some WD40 too... Smoke helped alot in this situation... Oh, And removing the tank helps. But yes it's a pain ! Good luck ! Recon.....
ForceRecon is offline
