What to do Butterfly removal problem - Kawasaki ZX-10R.net
post #1 of 32 Old 01-10-2010, 10:12 PM Thread Starter
BANNED
Bigcat#44's Avatar
So I am removing the secondary butterlies on my 07 and in the process 3 of the screws are jacked. Thats where the bad decision making started! I decided I've come too far to put it back together so I used an EZ out and pulled the 3 screws out. In the process of course there are small metal shavings and dust and while I got most of it, I wasn't able to get all of it so I'm sure some small dust got through the primary throttle bodies, in fact I know some did because I opened them to make sure I got it all and had to use my magnetic screw driver to pull some metal shavings out. Whatever did get in was a small amount of dust/very small particles, what should i do now?
Bigcat#44 is offline
post #2 of 32 Old 01-10-2010, 10:19 PM
flthy1's Avatar
Id go in with a really good magnet and spend some serious time cleaning them out and making sure I got them all. But I hear ya, some of them screws are tough
flthy1 is offline
post #3 of 32 Old 01-10-2010, 10:22 PM
Quick10's Avatar
I would do this and then change the oil again after 500 miles. Also add a magnetic drain plug.
https://www.zx-10r.net/forum/showthre...ighlight=flush
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #4 of 32 Old 01-10-2010, 10:30 PM
JLAudio11's Avatar
You can try sucking it out with a vacuum cleaner, either with tb's on or off. Or swabbing down in the intake tract with a paper towel with carb cleaner on it (helps pick up the dirt and cleans). Hopefully the valves were closed on the intake side otherwise it could be in the cylinder. If you want to get crazy you can always pull the head. If it's just some small dust don't worry about it will blow out the exhaust. It's not going to cause catastrophic failure. Dust and dirt in the cylinder will just wear down the cylinder walls more quickly. The key there is wear not bounce around forever beating everything to hell.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #5 of 32 Old 01-10-2010, 10:30 PM Thread Starter
BANNED
Bigcat#44's Avatar
Well I am going to do the oil change also but this went into the intake, will it damage the pistons/cylinders/rings? I'm concerned about running it. I used a pretty good magnet and pulled everything I could get to with it.
post #6 of 32 Old 01-10-2010, 10:32 PM
JLAudio11's Avatar
whatever particles are in there are not going to get past the rings into the bottom end. They will get blown out the exhaust on the first ignition.
post #7 of 32 Old 01-10-2010, 10:55 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Dude, I just did the same exact thing today. Luckily I only had to drill out 1 screw.
I just lined the throttle body with painters tape.
Once done, I blew it out, carefully removed tape, and I was good to go.
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #8 of 32 Old 01-10-2010, 11:16 PM
TENN10's Avatar
Images: 145
Hate to hear that.
I posted it somewhere deep inside the "other" thread, set a good magnet on the primary flies! Those screws are very soft.
TENN10 is offline
post #9 of 32 Old 01-10-2010, 11:58 PM
tasos's Avatar
Better to take the TB's out and clean them. You will also have more room for the to clean the ports of the head.
tasos is offline
post #10 of 32 Old 01-11-2010, 12:04 AM Thread Starter
BANNED
Bigcat#44's Avatar
Thanks ya'll!
Butterfly second erikspeed Race and Stunt 7 03-31-2008 12:48 PM
Exhaust Butterfly Valve Actuator Plug Connector removal kawaboy Performance and Tech 3 11-20-2007 03:48 PM
butterfly valve removal scream-n-10r Performance and Tech 11 10-19-2006 08:51 PM
Exhaust Butterfly livnpaintball Performance and Tech 9 01-28-2005 11:33 PM
Butterfly Exhaust Valve Actuator Removal. blipfth Performance and Tech 48 09-14-2004 07:35 PM
