Gen 1: 2004-2005 What brake lines for zx-6/zx-14 MC swap? - Kawasaki ZX-10R.net
post #1 of 9 Old 05-21-2012, 08:28 AM Thread Starter
dude's Avatar
Since the location of the banjo bolt is slightly different I figured I'd ask before I end up with the wrong thing. Do you guys just get steel lines for zx-6 or later year zx-10? Or do the 05 fit just fine? Seems like the end of the line will have to be bent at an angle so that it will point down...
dude is offline
post #2 of 9 Old 05-21-2012, 10:22 AM
SkyDork's Avatar
The stock lines will fit just fine. The angle isn't that sharp.
#WordCrimes
SkyDork is offline
post #3 of 9 Old 05-21-2012, 03:36 PM
Mythical Mod of Yore
wicked's Avatar
Send a message via AIM to wicked Send a message via MSN to wicked Send a message via Yahoo to wicked
but if youre going to the trouble of swapping master cylinders, you might as well put braided lines on too
wicked is offline
post #4 of 9 Old 05-21-2012, 04:25 PM Thread Starter
dude's Avatar
Yea sorry thats what i ment - was asking if the braided lines for the stock setup will fit the new setup with the zx6 mc or do i need to get different braided lines. They all seem to be mached against a speciffic model so which ones would i need to get?
dude is offline
post #5 of 9 Old 05-21-2012, 04:29 PM
SkyDork's Avatar
Get the lines for your bike. Only the length is slightly different between models. It has nothing to do with the connection at the banjo bolts. Those are all standard. If you haven't swapped calipers, then the length will be for the Gen 1.
#WordCrimes
SkyDork is offline
post #6 of 9 Old 05-21-2012, 04:31 PM Thread Starter
dude's Avatar
Will be swapping out the calipers for the zx-14 ones.
dude is offline
post #7 of 9 Old 05-21-2012, 04:38 PM
SkyDork's Avatar
Doesn't really matter. The banjo is at the top of the caliper on the Nissins, which will add a little service loop to the lines. You should still get the Gen 1 lines so you know you have enough length in them.
#WordCrimes
SkyDork is offline
post #8 of 9 Old 05-21-2012, 04:59 PM Thread Starter
dude's Avatar
Gotcha. thanks for the help guys!
dude is offline
post #9 of 9 Old 05-21-2012, 05:41 PM
Post Whore
-Op-'s Avatar
The other option is mock up the lines using your stock ones to test length with the different M/C and calipers and then contact HEL and they will make you lines to whatever length you want with whatever bend on the banjo you want.
-Op- is offline
WTB: Steel Braided Brake Lines And Brake Pads 04-05 ZX-10R HyperSpeedRacing Wanted: Buy or Trade 3 09-12-2009 09:12 PM
Attempting to do front caliper swap, ss lines, and levers??HARD??? xx8055NIACxx The ZX-10R 13 06-21-2009 12:45 PM
05 Calipers/pads/MC/Brake lever/brake lines jbl_91762 Parts, Gear and Accessories 0 05-03-2009 11:55 PM
06/07 nissin swap & stock lines? 2wheeler The ZX-10R 1 05-02-2009 12:07 AM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 01:29 PM
