what brake fluid do you use? - Kawasaki ZX-10R.net
post #1 of 18 Old 04-16-2011, 04:58 PM Thread Starter
Btrain87's Avatar
i did a search and to my surprise there wasn't already a thread on this. for those of you who don't know me, i'm on an 04 10r and just upgraded the brakes to nissin calipers, ss lines and zx-14 master. ( A MUST DO, IF YOU DIDN'T DO THIS YET) just curious since this is a such a common upgrade among people on this forum, what brake fluid are you running? also how do you like it and with this set up can you run dot 5.1/any real advantages if you can?
Btrain87 is offline
post #2 of 18 Old 04-16-2011, 06:30 PM Thread Starter
Btrain87's Avatar
Btrain87 is offline
post #3 of 18 Old 04-16-2011, 06:46 PM
Late Apex
Solo-Six's Avatar
Dot4 will work fine its what manual recommends but Dot5 will also work even better . Depends on your needs. Id do the Dot5 since you have ZX14 Master and any brand will do just fine ... Get it from the stealership or your favorite online store
Solo-Six is offline
post #4 of 18 Old 04-16-2011, 07:22 PM Thread Starter
Btrain87's Avatar
dot 5 with silicon your reccomending or 5.1? i've read that dot5 requires a full cleanse of the system where as 5.1 can be mixed?
Btrain87 is offline
post #5 of 18 Old 04-16-2011, 07:42 PM
09zx10miami's Avatar
Motul Dot 5
09zx10miami is offline
post #6 of 18 Old 04-16-2011, 07:46 PM
Send a message via Yahoo to caz345
06 ZX10R with the Nissin ZX14 calipers, Brembo 19RCS Master Cyl, Speigler SS Lines, and Im using Motul RBF 600 Brake Fluid, My lever moves about an 1/8" and its hard as a rock! Best mod Ive done.
caz345 is offline
post #7 of 18 Old 04-16-2011, 07:51 PM Thread Starter
Btrain87's Avatar
hmmmm ok! can you guys point me in the right direction as to how to fully cleanse my system then because i currently have dot 4 in it
Btrain87 is offline
post #8 of 18 Old 04-16-2011, 10:06 PM Thread Starter
Btrain87's Avatar
Btrain87 is offline
post #9 of 18 Old 04-17-2011, 12:54 AM
myblunt's Avatar
so like i just discovered this and i just happen to be doing my brakes tonight. basically i'm figuring to flush the dot4 and put in dot 5 i'll fix up the bleeders on the bottom with a bit of fuel tubing, open em up and just start pumping away until i've filled the reservoir a few times with dot 5. should be good 'nuff. i bought two bottles of that stuff so the first bottle will be used to flush, and then i'll fill and vent with the second bottle. *shrugs* its just brake fluid. I bought the only two bottles of the off brand dot5 at kragen today too.
myblunt is offline
post #10 of 18 Old 04-17-2011, 01:17 AM Thread Starter
Btrain87's Avatar
i hope other people chime in here because that would be fine if you were using dot 5.1. however, dot 5 is silicone based and when mixed with a dot 4 or any other fluid makes it a gel like substance and that is very bad lol. i believe you are supposed to put brake cleaner in and then blow the lines out with air. i'm not entirely sure how clean out the calipers and master though. hence my question lol. calipers may need to be split and have the pistons pop out to get a thorough cleaning, honestly at this point on speaking out of my arse lol so help from the gurus would be nice
Btrain87 is offline
Brake fluid ? R1HOOLIGAN General Motorcycle Discussions 2 02-07-2011 10:56 AM
Braided brake hoses brake fluid MrT Performance and Tech 6 10-30-2009 09:19 PM
Brake Fluid? NYC_ZX10 The ZX-10R 13 03-27-2007 01:25 PM
brake fluid vinja314 The ZX-10R 10 12-26-2006 10:35 PM
Brake Fluid?? nolaZX10 The ZX-10R 15 09-08-2004 09:35 PM
